The case of the broken boiler, this Fridays case
RayWohlfarth
RayWohlfarth Member Posts: 1,884
I think this is going to be an easy case. We started a new boiler we sold. The general contractor needed to get heat in the newly constructed building so the drywallers could finish the walls. After starting the boiler, checking the safety controls, and adjusting the air to fuel ratio, we left. A few weeks later, we were called by the mechanical contractor who installed the boiler. he said the new boiler wasn't working. When I arrived, the boiler had a broken temperature control hanging from two wires on the front of the boiler. The boiler was covered with white dust and the burner linkages were bent down at an odd angle. What happened to the boiler? I'll not comment till Friday when the video is released.
Ray
Ray Wohlfarth
Boiler Lessons
