Drain valve dripping from Oil Boiler
vermont_flatlander
Member Posts: 2
in Plumbing
This might be relatively simple for you experts but I'm fairly new to the plumbing DIY space.
We had a leak from a Taco Hy-Vent. In order to relieve pressure and remove water, I opened the drain valve from the oil boiler. I was able to drain it fine but when I closed it, there's now a very slow drip every couple of seconds. I think it's just very old and the valve just corroded in some way that it's not a full seal.
Anyways, I'm looking to replace it but I'm unsure if I can replace just the bibb/spigot or if I need to also replace what looks like a reducer behind it.
Attaching a screenshot for more info:
https://i.imgur.com/FOFjGeu.jpg
Appreciate any help!
Open and close a few times and pray you get lucky.If that doesn’t work they make caps for emergency use!0
They'll do that... which is why they make caps to fit over them. That's a hose bibb thread on the outlet, and I imagine that any decent hardware store or one of the Big Boxes will have them.Br. Jamie, osb
Should be able to take the packing nut off and take the stem out and replace the washer.0
- 50 Industry Classes
