Drain valve dripping from Oil Boiler
This might be relatively simple for you experts but I'm fairly new to the plumbing DIY space.
We had a leak from a Taco Hy-Vent. In order to relieve pressure and remove water, I opened the drain valve from the oil boiler. I was able to drain it fine but when I closed it, there's now a very slow drip every couple of seconds. I think it's just very old and the valve just corroded in some way that it's not a full seal.
Anyways, I'm looking to replace it but I'm unsure if I can replace just the bibb/spigot or if I need to also replace what looks like a reducer behind it.
Attaching a screenshot for more info:
https://i.imgur.com/FOFjGeu.jpg
Appreciate any help!
    pecmsg Member Posts: 7,275
    Open and close a few times and pray you get lucky.
    If that doesn’t work they make caps for emergency use!
    Jamie Hall Member Posts: 27,580
    They'll do that... which is why they make caps to fit over them. That's a hose bibb thread on the outlet, and I imagine that any decent hardware store or one of the Big Boxes will have them.
    mattmia2 Member Posts: 17,466
    Should be able to take the packing nut off and take the stem out and replace the washer.
    HVACNUT Member Posts: 7,525
    It's a lot easier to just replace the whole valve.
  • Intplm.
    Intplm. Member Posts: 3,081
    Ask for a boiler-drain cap at your nearest hardware or plumbing supply house.
    Hand tighten till the drip stops.
    STEAM DOCTORTom_133
