Update boiler or stay the course?
Update boiler or stay the course? 13 votes
Keep current inefficient boiler and indirect DHWSpeaking as a homeowner;
If it is not leaking I would not replace it. At most it needs a good cleaning and burner tune up and perhaps a can of Fernox in the boiler water.
Adding insulation if possible and adding water storage in the basement if there is room will save you energy as a boiler hot water storage tank like the 425 gallon New Horizons rectangular fully insulated tank on the return side would provide you with more warm feed water for the boiler sump and provide more thermal mass.
The return header piping would need to be changed to feed the cooler return water from the heating loops into the New Horizons fully insulated tank and back to the boiler sump line.0 -
Keep current inefficient boiler and indirect DHWHow inefficient in considered inefficient?
What type of emitters do you have?
If you ran the boiler temp at the lowest possible output and it still heated the house, what would the return water temp be?
High efficiency is dictated by the return water temp, if too high for condensing then that perhaps extra 10 % may not be had.1 -
I don't have the book right by me but I believe it is approx 85%. Emitters? Baseboard if that is where the heat is emitted to the room.0
Look at it this way. IF you have enough baseboard to have the return temperature always below about 140, then the most additional efficiency you could attain is 10%. So you fuel bill might decrease by that 10&. Otherwise, you won't be getting the additional efficiency the label proudly states, and you won't be saving much if anything. So how many years will it take, saving 10% on your fuel bill, to pay off a new boiler? Quite a few...
If it ain't broke, don't fix it.Br. Jamie, osb
Keep current inefficient boiler and indirect DHWUnless you have that much extra disposable income, leave it alone. Mad Dog 🐕2
Keep current inefficient boiler and indirect DHWThat boiler should last a long time.All Steamed Up, Inc.
Consulting1 -
Keep current inefficient boiler and indirect DHWI might consider getting a dedicated water heater for DHW. Then in January when the boiler dies, you can still take a hot shower. In the summer you can shut the boiler down for several months for maintenance, waiting for parts, etc.0
@CTH3 What did you use for the pipe insulation? Armacell or the cheap stuff at big box store? Nice job with it by the way. Looking to do the same thing myself. Looks like 1/2" thick. I'm going to try for 1" if it will fit. Was it too difficult to miter the fittings? I've also heard insulating the basement has decent ROI. Haven't done it myself, but it's something I'm considering.0
Keep current inefficient boiler and indirect DHWThe discharge pipes from the relief valves need to go all the way to the floor so they don't spray anyone in the area with hot water if they discharge. It looks like the element of the t&p valve for the indirect isn't in a place where the probe reaches inside the tank but it is hard to tell from this picture.0
Unfortunately there is some noise. I have the heat turned off now but the indirect DHW continues. When heating the water there is a non-rhythmic, intermittent rattle type noise. It is not the same noise of the baseboard heating when the pipes are making noise. I put my ear near the taco circulator but can not hear any noise there.hot_rod said:A lot depends on the water water, how often it cycles. Any non barrier tubing in the system?
Does it make any noise when it heats up?0 -
About 900 gallons of LP for heat, hot water and cooking. Also have a DHW circulator set for morning and evening. We have an RSF fire box/fireplace that we burn all winter which keeps our LR in the 70s We have 13+ acres and I cut my own firewood.Hot_water_fan said:I'd keep until failure. How much fuel do you use per year?
Aware on the discharge pipe. I just haven’t gotten around to fixing that…….because I had to put a second PRV in due to the original now sticking up higher after installing the bypass. The second one is installed in an auxiliary access and it has an 8 inch probe. It is kind of obscured.mattmia2 said:The discharge pipes from the relief valves need to go all the way to the floor so they don't spray anyone in the area with hot water if they discharge. It looks like the element of the t&p valve for the indirect isn't in a place where the probe reaches inside the tank but it is hard to tell from this picture.
I went with the cheap stuff. Unfortunately when we built the house in 1999/2000 I did not wrap all hot water piping. I only did visible pipes in basement. The rest are in insulated walls. I will look up Armacell.random12345 said:@CTH3 What did you use for the pipe insulation? Armacell or the cheap stuff at big box store? Nice job with it by the way. Looking to do the same thing myself. Looks like 1/2" thick. I'm going to try for 1" if it will fit. Was it too difficult to miter the fittings? I've also heard insulating the basement has decent ROI. Haven't done it myself, but it's something I'm considering.
A rumbling, piping, percolation sound could indicate sediment or scale in the boiler. No harm in running a cleaner in the system and see what flushes out. Efficiency goes up with clean heat exchange surfacesCTH3 said:
It’s really hard to predict life expectancy
Keep current inefficient boiler and indirect DHWI voted leave it, but I didn't know you were using LP. Maybe get a hybrid hpwh could maybe pipe it in series with your superstore if possible. Or just use both and switch over between seasons. Just a couple of valves. That would allow you to shut it down entirely during the summer.0
I noticed that too, my guess is so heat from the system doesn't migrate up to the emitters in the house during the off season?JakeCK said:HVACNUT said:Why are 2 zones valved off?
When heating season is over I turn all the gates off except DHW. The one is on because it got a little chilly earlier this week and it was only 68 in the house when I got up.
p0
Only 68? 🙃 Lol when I was younger and family free I used to keep the house at 66-68 not only to save money but because I found it comfortable. Once the heating season is over I don't even consider turning that beast back on unless it drops below 60.CTH3 said:p0 -
That’s more like our bedroom. When we were in the upstairs BR the heat was on only when we were up there for an extended purpose. So 64-62 at night was great with an electric blanket.JakeCK said:
Now we are older and downstairs. I’ll post a pic after this. These are the Ty inns that look in our window0 -
Keep current inefficient boiler and indirect DHWHeyyyy Boo Boo...let's find us some pick-a-nick baskets!!!! I'm smarta than the avaaaridge bear! 🐻 .Mad Dog 🐕0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
