Why I turn off the pilot
On a side note I turned the basement dehumidifier on about a month ago. I have had to empty it exactly once. Sure we are experiencing some really dry weather right now but I used to have to empty it at least twice a day in the spring. I don't know what contributed to this the most, the polyiso on the foundation, or the repair of the storm and footer drains, but I'm not complaining. It's staying a lot cooler down there as a result.
On the flip side, a 100 watt bulb can come in real handy as a spot warmer. Not just chicks and so on, but we have a well pit in one place which is at risk of freezing in the winter -- and we just leave the 100 watt light in the pit on in the winter. No problem.Br. Jamie, osb
There was a farmer with the cold pump pit problem.
The light bulb was enough heat.....but out of sight....was it burned out or not?
So I set up 2 bulbs in series, maybe the 100 in the pit and a 25 within sight.
Not sure of the sizes, it may have taken a little experimenting.
But when outside bulb was on the buried inside bulb was good.1 -
or just use a pair of 240v lamps and check on it occasionally. the 240v lamps will last for years at the reduced voltage although the output isn't easy to calculate because the filament is a thermistor, its resistance decreases as it gets cooler so it has a lower resistance if you burn it at reduced voltage so it uses more power than you would expect if you assumed it was linear.JUGHNE said:There was a farmer with the cold pump pit problem.
But when outside bulb was on the buried inside bulb was good.0 -
I think we settled on both being 100 watts. In series halving the voltage at each would only produce 25watts....no?
In any event it was enough to keep things from freezing.0 -
Not quite because the resistance of the filament changes with temp so if you don't burn it at full voltage it is cooler and the resistance is less. This is for a 6v lamp but the same thing happens with a 120v or 240v lamp:JUGHNE said:In series halving the voltage at each would only produce 25watts....no?
Not quite because the resistance of the filament changes with temp so if you don't burn it at full voltage it is cooler and the resistance is less. This is for a 6v lamp but the same thing happens with a 120v or 240v lamp:Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
My parents old house had a partial basement, about 400 sq ft. I replaced their boiler with a (dad supplied HD special) Slant Fin atmospheric with the vent damper. The following summer I found you could spontaneously combust from only the standing pilot just walking down the stairs. From then on I would shut the gas to the boiler and relight/check in the fall.
what is an "always on" igniter?0
The only kind I can think of is a standing pilot. That's always on.john123 said:what is an "always on" igniter?
Unless they meant a hot surface igniter, but those aren't always on, they're only hot when the burner runs.
I was thinking about leaving a hot surface igniter on all the time. Maybe it's repeated heat up cool down cycles that eventually kill it?0
it is both the cycle and the being hot. i suspect it would only last a few weeks to months if you keep it always hot. my furnace has a system that supposedly modulates the power so it only gets hot enough to ignite the gas and it has lasted about 22 years so far. I think it only energizes it until it proves flame as well so it saves wear that way too.jumper said:I was thinking about leaving a hot surface igniter on all the time. Maybe it's repeated heat up cool down cycles that eventually kill it?
https://forum.heatinghelp.com/discussion/188163/wow-that-uses-a-lot-more-energy-then-i-thought/p1
One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
https://forum.heatinghelp.com/discussion/188163/wow-that-uses-a-lot-more-energy-then-i-thought/p10
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
