Will replacment boiler be needed ??
Niss3zx
Member Posts: 10
in Gas Heating
Looks like a steam boiler that has rusted out above the waterline. If so, it's time for a moment of silence.
In the first pic, the return line near the floor that goes to the Hartford Loop looks like it's rusted out too.All Steamed Up, Inc.
Consulting1 -
It’s a Burnham Independence that’s been murdered.0
Again I am no plumber. I have a little knowledge. Should i fill boiler to top. Afraid to introduce new oxygenated water into system.
Any way of testing ?? Cleaned as best and vaccumed. Your thoughts if replacment is needed.
As a professional, I would suggest beginning the process of replacing the boiler. Consider not using an automatic feeder this time, or at the very least, use a HydroLevel VXT.The first step in beginning the boiler replacement process would be to find a contractor who will measure all the connected radiation to properly size the new boiler, as well as review the system in totality, not simply the boiler.5
You MAY get a few more years out of it but do you really want it letting go on Christmas 🎄 Eve? Chanukah? Get Johnny NY from Gateway/Toro out there. They service Brooklyn and know The Steam...Mad Dog 🐕0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
