14" Toilet Rough-in
That's looks like a perfectly good water closet. Does it flush poorly? Running? Cracked? Why are you changing it? I've found many people were happier just rebuilding the innards. Mad Dog 🐕
3 -
They make ADA height toilet seats that will add a few inches and usually make a big difference. I would try that first. Save alot of time & $$$. Moreover, many of the newer low flush toilets don't perform so great. Mad Dog 🐕0
Thanks Mad Dog I'll check them out.Mad Dog_2 said:They make ADA height toilet seats that will add a few inches and usually make a big difference. I would try that first. Save alot of time & $$$. Moreover, many of the newer low flush toilets don't perform so great. Mad Dog 🐕
Agree with MadDoggy. If I must replace my first inclination is to use standard and cover gap with a shelf. Probably try Alien tape for that.0
Improper use of the name "Water closet" 10 point penalty.Mad Dog_2 said:That's looks like a perfectly good water closet. Does it flush poorly? Running? Cracked? Why are you changing it? I've found many people were happier just rebuilding the innards. Mad Dog 🐕
Toto makes toilets with 14" rough in and "comfort height"...i installed one and like it. Going to add second one soon. It is a little expensive and there is still a1" gap from tank to wall.
https://api.ferguson.com/dar-step-service/Query?ASSET_ID=4544185&USE_TYPE=SPECIFICATION&PRODUCT_ID=4555351
Well, my wife really likes this one. I'll have to see if it's possible. Thanks.SlamDunk said:Toto makes toilets with 14" rough in and "comfort height"...i installed one and like it. Going to add second one soon. It is a little expensive and there is still a1" gap from tank to wall.
https://api.ferguson.com/dar-step-service/Query?ASSET_ID=4544185&USE_TYPE=SPECIFICATION&PRODUCT_ID=45553510 -
Toto has several models of toilets with the unifit trap to look at. And to @hot_rod point, these toilets have a large skirt that will absorb an old toilet's footprint. The seat is incredibly chinzy for the price of toilet. We tossed it and bought a better one from lowes. Good luck!0
What is the distance between the back of the tank and the wall. 14" rough ins were popular in the "30"s and "40"s. I have only come across them in houses in that era.
I think that toilet is a 12" rough in and that tank is 2" away from the wall. There may be a 14" rough in hub with a newer 12" rough in toilet.0 -
The house was built in 1940 but the bathroom was renovated at some point. Maybe 70's? Just guessing from the color of the fixture. Just checked and the tank is snug against the wall.HomerJSmith said:What is the distance between the back of the tank and the wall. 14" rough ins were popular in the "30"s and "40"s. I have only come across them in houses in that era. I think that toilet is a 12" rough in and that tank is 2" away from the wall. There may be a 14" rough in hub with a newer 12" rough in toilet.
My toilet had a wall mounted tank with a two inch chrome ell connecting to bowl. 1930. It had a gap of just an inch with toto. It is annoying but better than 2"0
I've seen shelves bridging gap and nobody notices but me when I have to work in tank.0
- 15.8K Strictly Steam
