Will replacment boiler be needed ??
Niss3zx
Niss3zx Member Posts: 10
    Jamie Hall Member Posts: 26,807
    Possibly -- but there would be no harm to trying to clean it first. But if that's from a leak, and not just crud over time, yeah...
    Mad Dog_2
  • Big Ed_4
    Big Ed_4 Member Posts: 3,354
    edited June 2023
    Possible condensing problem ...
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 19,487
    I would suspect a leaking boiler. Clean the crud off and pressure test it first
    Mad Dog_2
    Steamhead Member Posts: 18,186
    Looks like a steam boiler that has rusted out above the waterline. If so, it's time for a moment of silence.
    In the first pic, the return line near the floor that goes to the Hartford Loop looks like it's rusted out too.
    Consulting
    Mad Dog_2
  • JUGHNE
    JUGHNE Member Posts: 11,508
    Overfill the boiler up to the main piping (it will get cold, then stop).
    Clean crud away and you may well see water exiting.
    Then you are certain.
    Niss3zxMad Dog_2
  • Danny Scully
    Danny Scully Member Posts: 1,465
    edited June 2023
    It’s a Burnham Independence that’s been murdered.
    The murderer can be seen in the first picture 😉
    Where are you located @Niss3zx?
  • Niss3zx
    Again I am no plumber. I have a little knowledge. Should i fill boiler to top. Afraid to introduce new oxygenated water into system.  Any way of testing ?? Cleaned as best and vaccumed. Your thoughts if replacment is needed.
  • Niss3zx
    Im located in Brooklyn. Yep. Filled up water to top and small weeping. Time for a replacment. You think i can get by another year ??
    Mad Dog_2
  • Niss3zx
    pecmsg Member Posts: 6,761
    No
    time to look into replacing it.
    Take your time.
    Size it probably.
    Choose your installing contractor wisely
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,379
    You MAY get a few more years out of it but do you really want it letting go on Christmas 🎄 Eve?  Chanukah? Get Johnny NY from Gateway/Toro out there.   They service Brooklyn and know The Steam...Mad Dog 🐕
