Coal fired
unclejohn
Member Posts: 1,833
Cool...is that is Penna? I'm more familiar with the Mennonites of the Finger Lakes. Very interesting folks. Both Anabaptists. Do you know them well? Mad Dog 🐕0
For some reason it wont load my screenshot0
It’s near here. camden-wyoming moose lodge 2030
The boiler looks like a DS Machine unit. I wonder how the rest of the system is piped? The pipe size is quite a bit smaller than a traditional gravity system.
There are amish people in every state probably, but very few in Hawaii.
I had lunch at John's Pizzeria on Bleecker street the other day, they have a coal fired oven and they were loading it up while I was there, it was pretty cool.NJ Steam Homeowner.
I do not think that hand fed gravity hot water coal fired boiler is a DS Machine boiler.
About Coal fired pizza ovens; Stove size Anthracite Coal is typically used in coal fired pizza ovens.
The coal fire is kept in the back corner of the oven and not piled high allowing good combustion to occur and heat the fire brick on the floor roof and sides of the oven. The heat is constant and even across the
oven floor allowing the smaller pizzas thinner crust to be fully baked in a very, very, short time usually less than 2 minutes.1 -
Are they Horse & Buggy Amish in Hawaii? I know Mennonite much better. They own John's 🍕 on Bleecker? They donrun a few produce stands...The best Coal-Fired Pizza is Patsy's on 118th Street in East Harlem (Fat Tony Salerno's old hood). Its been smoldering non stop since 1933. Large slices...no frills shop. Lines go around the block but move fast. The Restaurant next store is also very good. While your up there, peek in to Rao's ..they'll hold a table for ya....In 20 years when one frees up! Ha ha. Mad Dog 🐕 🤣1
Amazing how different things are based on region. I can throw a stone in any direction and hit 5 coal boilers, but have literally only seen 1 oil boiler in my entire life.0
@unclejohn; you can tell that they burn hard coal since the boiler room walls and floor are clean. If they burned soft coal the room would a darker color. Where I am located we serviced both hard and soft coal, #1, #2, #6, fuel oil, natural gas, a little propane and even a few sewer gas units. The boiler for the Ebensburg, Pa sewage plant got about 50% of their heat to keep the poop warm and the digesters working at maximum from sewer gas. To see the flame you had to turn off all the lights and view the flame in the dark.2
I wish we could obtain oiled Western Sub Bituminous Stoker Coal from Montana or Wyoming here in the east as I would have 90% less coal ash to deal with.0
Are you sure you are not speaking of anthracite coal. Sub-bituminous coal has a very low heat value. It's BTU value is just above lignite. I never burned it but it would probably produce a lot of ash and my even be hard to burn.0
Coal does not go bad like heating oils can. So if there's enough room then big advantage in case of fuel delivery interruption.GroundUp said:Amazing how different things are based on region. I can throw a stone in any direction and hit 5 coal boilers, but have literally only seen 1 oil boiler in my entire life.
------------------------------------------------------------------------------------------retiredguy said:Are you sure you are not speaking of anthracite coal. Sub-bituminous coal has a very low heat value. It's BTU value is just above lignite. I never burned it but it would probably produce a lot of ash and may even be hard to burn.
The Western Sub Bituminous coal from The Provinces of British Columbia and Alberta, the States of Alaska, Wyoming and Montana burns very hot and quick due to the volatiles in it releasing more easily as it is more friable than bituminous coal. and it produces little smoke and a very small amount of ash compared to Anthracite coal from England or the states of Colorado and Pennsylvania.
Lignite is referred to as Slack Coal in England.
Neither does firewood. Although, coal isn't affected by water.jumper said:Amazing how different things are based on region. I can throw a stone in any direction and hit 5 coal boilers, but have literally only seen 1 oil boiler in my entire life.
Coal does not go bad like heating oils can. So if there's enough room then big advantage in case of fuel delivery interruption.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 15.8K Strictly Steam
