Cleaner for old copper pipe
MikeAmann
MikeAmann Member Posts: 998
Mom's house - I will be replacing some old 1/2" Solder Ends Stop & Waste Valves with ball valves. Naturally, the copper pipe is brown and dirty. Is there a product, say a spray-on or brush-on that I can use to help to get the copper clean? I would like to be able to wipe off most of the dirt and oxidation before the wire brush/sandpaper is used. I hate to have that dirt transferred to the wire brush, and then all you are doing is carrying that dirt along to the next joint.
    pecmsg Member Posts: 4,870
    Sand cloth
    hot_rod Member Posts: 22,201
    Brasso works also
    Jamie Hall Member Posts: 23,373
    Or Noxon
  • Mad Dog_2
    Mad Dog_2 Member Posts: 7,049
    If you're resoldering, I would not use any chemicals.  Open Mesh plumbers grit cloth is the best (not the sandpaper like Emery cloth).  It will even take off paint.  Clean it up to a high shine, clean Flux and away you go.  If you're going for a decorative finish, ( you could use Brasso or whatever....but not to resolder copper tubing.  Mad Dog 🐕
    PC7060Derheatmeister
    EBEBRATT-Ed Member Posts: 15,574
    Agree with Mad dog open mesh sand cloth
  • MikeAmann
    Yes, for resoldering. Open mesh sand cloth - good idea. That shouldn't hold the dirt.
    EdTheHeaterMan Member Posts: 7,920
  • MaxMercy
    MaxMercy Member Posts: 508
    Tarn-X. Rinse after you clean the pipe.
  • kevink1955
    kevink1955 Member Posts: 88
    We were in Detroit years ago and visited 1 of Henry Fords buildingd that had a room with all polished copper and brass valves. It was a plumbing work of art. As I remember it was a manifold system but much nicer then the PEX stuff you see today Lol
    Has anyone seen it and remember the name of the building, sure would like to see pictures of it.
    Mad Dog_2
  • Mad Dog_2
    Wow! Kevin, I would love to see it.  Dan probably has...Mad Dog 🐕
  • kevink1955
    Now that I think about it it may have been all threaded brass, it was a work of art.
    I am sure I took pictures but have no idea where they went.
    Mad Dog_2
