Cleaner for old copper pipe
Mom's house - I will be replacing some old 1/2" Solder Ends Stop & Waste Valves with ball valves. Naturally, the copper pipe is brown and dirty. Is there a product, say a spray-on or brush-on that I can use to help to get the copper clean? I would like to be able to wipe off most of the dirt and oxidation before the wire brush/sandpaper is used. I hate to have that dirt transferred to the wire brush, and then all you are doing is carrying that dirt along to the next joint.
Sand cloth0
Brasso works alsoBob "hot rod" Rohr
Living the hydronic dream0 -
Or NoxonBr. Jamie, osb
If you're resoldering, I would not use any chemicals. Open Mesh plumbers grit cloth is the best (not the sandpaper like Emery cloth). It will even take off paint. Clean it up to a high shine, clean Flux and away you go. If you're going for a decorative finish, ( you could use Brasso or whatever....but not to resolder copper tubing. Mad Dog 🐕2
Agree with Mad dog open mesh sand cloth0
Yes, for resoldering. Open mesh sand cloth - good idea. That shouldn't hold the dirt.0
didn't we have this discussion last month? https://forum.heatinghelp.com/discussion/comment/1745487#Comment_1745487
Tarn-X. Rinse after you clean the pipe.
We were in Detroit years ago and visited 1 of Henry Fords buildingd that had a room with all polished copper and brass valves. It was a plumbing work of art. As I remember it was a manifold system but much nicer then the PEX stuff you see today Lol
Has anyone seen it and remember the name of the building, sure would like to see pictures of it.1 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
