Left-handed ball valves ???
MikeAmann
MikeAmann Member Posts: 998
For a small project that I am doing, I ordered the ball valves on the left. When I went to lay them out as to where they will go and their orientation, I noticed something "funny".
Does anyone else see what I am looking at?
    mattmia2 Member Posts: 9,704
    You can take the handle off and reverse the arc it swings. I guess where the waste is is sort of arbitrary.
    I just came here to leave a comment about a left handed and metric crescent wrench.
    MikeAmann
  • MikeAmann
    Yes, I reversed the handle for quite a few places.
    I have a couple of tight spots where I must use the conventional bleeder location.
    But likewise, this configuration works better in a few other places.
    Jamie Hall Member Posts: 23,373
    Watch out. I'll have you go to ship's stores for a couple of fathoms of shore line...
    hot_rod Member Posts: 22,201
    MikeAmann said:
    Yes, I reversed the handle for quite a few places. I have a couple of tight spots where I must use the conventional bleeder location. But likewise, this configuration works better in a few other places.
    T handles are available for many valves, if that helps
    mattmia2Intplm.
    EBEBRATT-Ed Member Posts: 15,572
    Or a hacksaw on the handle
    EdTheHeaterMan Member Posts: 7,918
    Don't you need a left handed torch to solder those valves in place?
    Intplm.
  • dko
    dko Member Posts: 607
    "need one with 1" on the left and one with 1" on the right"
    EdTheHeaterManCLamb
  • Intplm.
    Intplm. Member Posts: 1,981
    I like the comments on this thread.
    There is a company that makes a ball valve that can be switched around from left to right.
    I've used them on large commercial jobs. They can be installed in very tight spaces. The handle is easily switched without worrying about losing the stop.
    Check out Cimberio. One of the best valves I've seen.
  • ChrisJ
    ChrisJ Member Posts: 15,734
    I've had ball valves that the nut was barely hanging on brand new. I think they stripped out when I tried to move the handle.
    All of my recent valves had much better threads and thicker nuts. For quite a while now I've only used Apollo and Webstone.
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
    edited May 2023
    Oh stop it... you are taking this much too seriously. This post is from the comic relief department. Get with the program. Here is a place to use your metric Crescent wrench set https://www.youtube.com/watch?v=E6GsXhBb10k.
    Available on Amazonhttps://www.amazon.com/Blinker-Fluid-HAND-VERSION-Hilarious-Gift-Stocking-Stuffer-Car/dp/B06ZXSKDZG
    GGrossIntplm.
  • mars_6
    mars_6 Member Posts: 107
    Can I get some of that at Ace?
  • GGross
    GGross Member Posts: 1,060
    @mars_6
    Don't forget to pick up some elbow grease while you are there
    EdTheHeaterManIntplm.
