Left-handed ball valves ???
You can take the handle off and reverse the arc it swings. I guess where the waste is is sort of arbitrary.0
Yes, I reversed the handle for quite a few places.
I have a couple of tight spots where I must use the conventional bleeder location.
But likewise, this configuration works better in a few other places.0 -
Watch out. I'll have you go to ship's stores for a couple of fathoms of shore line...mattmia2 said:I just came here to leave a comment about a left handed and metric crescent wrench.
MikeAmann said:Yes, I reversed the handle for quite a few places. I have a couple of tight spots where I must use the conventional bleeder location. But likewise, this configuration works better in a few other places.Bob "hot rod" Rohr
Living the hydronic dream2 -
Or a hacksaw on the handle0
I keep the complete set in both SAE and Metricmattmia2 said:I just came here to leave a comment about a left handed and metric crescent wrench.
And the left handed set as well
6 -
I like the comments on this thread.
There is a company that makes a ball valve that can be switched around from left to right.
I've used them on large commercial jobs. They can be installed in very tight spaces. The handle is easily switched without worrying about losing the stop.
Check out Cimberio. One of the best valves I've seen.0 -
I've had ball valves that the nut was barely hanging on brand new. I think they stripped out when I tried to move the handle.
All of my recent valves had much better threads and thicker nuts. For quite a while now I've only used Apollo and Webstone.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Oh stop it... you are taking this much too seriously. This post is from the comic relief department. Get with the program. Here is a place to use your metric Crescent wrench set https://www.youtube.com/watch?v=E6GsXhBb10k.Intplm. said:I like the comments on this thread.
Available on Amazonhttps://www.amazon.com/Blinker-Fluid-HAND-VERSION-Hilarious-Gift-Stocking-Stuffer-Car/dp/B06ZXSKDZG
2 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
