Tankless WH - Expansion tank?
If not required, is it beneficial?
I think all the plumbing codes require a thermal expansion “device” on water heaters
A small tank like this works for tankless and combis with small water contentBob "hot rod" Rohr
Living the hydronic dream1 -
My municipality doesn't require a backflow preventer on the supply into the house. The city water system is my expansion device.
Ok.......ethicalpaul said:My municipality doesn't require a backflow preventer on the supply into the house. The city water system is my expansion device.
Laugh if you want
, but I believe this is commonplace!
Time to dig out the Good Grief meme again.
Hi, Thinking about the physics going on with a tankless around a hot water draw and afterwards, I think it would be a fun project to actually test pressure just before, during and for about 1/2 hour after the draw in a "closed" system. If anything, the pressure might drop as plumbing and heater cool down. In that case, more water would enter the system. I'm not seeing a way for high pressure to develop or become a problem. I almost never see expansion tanks used with tankless and never hear of over-pressure problems. Maybe I live in Shangri La?
Yours, Larry0 -
I tend to agree with you, @Larry Weingarten -- but the question isn't really the physics, it's the code and authority having jurisdiction. Isn't it always?Larry Weingarten said:Hi, Thinking about the physics going on with a tankless around a hot water draw and afterwards, I think it would be a fun project to actually test pressure just before, during and for about 1/2 hour after the draw in a "closed" system. If anything, the pressure might drop as plumbing and heater cool down. In that case, more water would enter the system. I'm not seeing a way for high pressure to develop or become a problem. I almost never see expansion tanks used with tankless and never hear of over-pressure problems. Maybe I live in Shangri La?
Yours, LarryBr. Jamie, osb
I think the new 2023 very expensive Bradford White propane water heater I have has a check valve in it already to prevent ghost flow0
This is about expanding with temperature, not ghost flow.
Very good point.....leonz said:I understand that, I mentioned the check valve in my Bradford White Water heater simply because the water flow stops there when the demand stops.
- 119 Chimneys & Flues
- 76 Pipe Deterioration
