Tankless WH - Expansion tank?
ChrisJ
ChrisJ Member Posts: 17,275
I'm curious, is an expansion tank required with a tankless water heater when a RPZ is used?
If not required, is it beneficial?
    pecmsg Member Posts: 7,017
    Doesn't hurt.
    SuperTech
    hot_rod Member Posts: 27,284
    I think all the plumbing codes require a thermal expansion “device” on water heaters
    A small tank like this works for tankless and combis with small water content
    GGross
    ethicalpaul Member Posts: 8,621
    My municipality doesn't require a backflow preventer on the supply into the house. The city water system is my expansion device.
  • ChrisJ
    Ok.......
    :D
    SuperTech
    Laugh if you want :smiley:, but I believe this is commonplace!
    SuperTech
  • ChrisJ
    Time to dig out the Good Grief meme again.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,064
    Hi, Thinking about the physics going on with a tankless around a hot water draw and afterwards, I think it would be a fun project to actually test pressure just before, during and for about 1/2 hour after the draw in a "closed" system. If anything, the pressure might drop as plumbing and heater cool down. In that case, more water would enter the system. I'm not seeing a way for high pressure to develop or become a problem. I almost never see expansion tanks used with tankless and never hear of over-pressure problems. Maybe I live in Shangri La? :)
    Yours, Larry
    Jamie Hall Member Posts: 27,205
    Yours, Larry
    I tend to agree with you, @Larry Weingarten -- but the question isn't really the physics, it's the code and authority having jurisdiction. Isn't it always?
  • leonz
    leonz Member Posts: 1,799
    I think the new 2023 very expensive Bradford White propane water heater I have has a check valve in it already to prevent ghost flow
  • ChrisJ
    This is about expanding with temperature, not ghost flow.
  • leonz
    I understand that, I mentioned the check valve in my Bradford White Water heater simply because the water flow stops there when the demand stops.
    ChrisJ
  • ChrisJ
    Very good point.....
