rusted collar unconnected - not a professional
Hi, we live in a co-op building in NYC built in 1956 with classic 2.5" floor to ceiling steam pipes in the bathrooms. We'd had what I thought was a messy join to the ceiling with caulk, but when I stripped it, it's a rusty collar that doesn't seem to connect to anything - the pipe wiggles and squeaks in the socket when pushed - and the collar is smashed on one side.
I would love to remove this and either have a clean seam at the ceiling or use a concentric reducer to cover the join, but I don't know what this piece is and if it can safely be removed.
We don't have control over the steam pipe being on or off until after the weather goes above 55 degrees or April 15th.
Any guidance I can get would be very helpful. Thanks.
  • Ironman
    Ironman Member Posts: 7,902
    Since you're not even sure what it's connected to, and it's 2-1/2", I'd recommend that you call a pro.
    Try the contractor locator above.
    Bob Boan
    STEVEusaPAMad Dog_22244BPE
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,524
    The Johnny NY with Gateway P & H.. they're very good and in the neighborhood. Mad
    2244BPE
    pecmsg Member Posts: 7,027
    Thats part of the building so the CoOp board should deal with it!
    mattmia2 Member Posts: 16,541
    That kind of looks like the end of a piece of aircell asbestos insulation on the pipe above there compressed against a joist so I'd be careful about what I picked at up there.
    2244BPEMad Dog_2
  • 2244BPE
    2244BPE Member Posts: 2
    Thanks for the help. I spoke to the super and his (always helpful) comment was "you're having the bathroom ceiling redone, right? Let them handle it." So thank you for the recommendations if they are lost too. Also, I'm on the co-op board.
    Mad Dog_2
    hot_rod Member Posts: 27,352
    there may need to be a fire stop product used also?
  • bburd
    bburd Member Posts: 1,296
    edited March 2023
    That collar is designed to allow the pipe to move from thermal expansion and contraction as it heats and cools, so whatever you do must allow for that movement or it will crack on the first heating cycle. That is why those are generally not caulked, the movement is too significant.
    Bburd
