Mitsubishi Mini Split Drain connection
What is the best way to connect 3/4” pvc to the cassette drain? The Mitsubishi drain has a soft connector which doesn’t allow a pipe clamp. Does it just push inside a 5/8” vinyl hose without a pipe clamp?
Try clamping it to the outside of a ¾" fitting.
my mini split drain goes through a hole in the wall leading directly outside. The flexible drain tube then slides into the 3/4 pvc drain pipe leading down the outside wall. Why do you need to connect rigid pipe directly to pan?
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.0 -
doesnt the 3/4 pvc glue into that flexible adapter sleeve that comes with the ceiling unit?
Thanks all!
Hey Gyrfalcon, it's on an inside/interior wal and needs to be routed to a drain. Thanks.0 -
odd—-we did a few recently and regular PVC fit perfectly. I bought hose clamps to make a 'better fit' (not too small not too big).
'…wall tumor…', lol, perfect!
They're sooooo ugly. I'd certainly go with ceiling cassettes or ducted models if I went that way.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 963 Plumbing
- 385 Solar
- 15.3K Strictly Steam
