Changing old thermostat with emergency heat to a smart type
  • Tom E
    Tom E Member Posts: 15
    had a new heat pump installed last year and I would like to update the thermostat. Is it a straight forward swap? Thanks
    pecmsg
    pecmsg Member Posts: 7,039
    Best to get the installing contractor to set it up. If they  do something wrong warranty will cover it.
    Tom E
    Jamie Hall Member Posts: 27,313
    That is a lovely old thermostat, and absolutely bulletproof. Nothing new you install will work as well or as reliably...
    Tom E
