Squirrels...
JakeCK
JakeCK Member Posts: 1,498
edited March 2023 in THE MAIN WALL
Lost a solar panel a few weeks ago, installers finally got out to investigate today. This is what they found. Luckily the panel and micro were still good to go. I find it a bit funny that they choose the houses roof to build a nest on vs the garage. The house is 2 1/2 story's up with a 10/12 pitch with no trees close(flying squirrels?). The garage in comparison I can easily jump on to with a 8ft ladder, is a low pitch(I can about dance on it) and has easy access to trees/shrubs and to the power lines. O.o
How squirrely 🐿️
Mad Dog_2GGross
  • ChrisJ
    ChrisJ Member Posts: 16,851
    This is a family forum Jake.....
    Mad Dog_2
  • SlamDunk
    SlamDunk Member Posts: 1,761
    A friend has a ford truck and squirrels chewed thru two wire harnesses. He found out that the wiring had environmentally safe insulation made, in part, with soy beans.
    HomerJSmithMad Dog_2
  • JakeCK
    Not the first I've heard this. Didn't know if it was true or not. Im going to look into screen that goes around the perimeter.
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,267
    Not a big fan of squirrels.  Especially, Red Squirrels...very mean, nasty, extremely violent and aggressive.  They eat and attack  EVERYTHING,  including 🐿 Chipmunks (My favorites).  Maine is full of them!   Mad Dog
    kcoppMarjPinard
  • JUGHNE
    JUGHNE Member Posts: 11,459
    I had to rewire in an attic that had become the home of squirrels.
    They enjoyed chewing the thermoplastic outer sheath of "Romex" cables, even the individual wire insulation under that, down to the bare copper. This was Romex from about 1980.
    The knob and tube wire insulation was not touched nor the early non plastic Romex cables.
    They are rats with a cute tail.
    JakeCKkcoppMikeAmannMarjPinard
    mattmia2 Member Posts: 13,499
    Are you sure it's not rats?
  • JUGHNE
    I could see them on the roof after their entrances were sealed.
    I was in the attic under one of the openings that got sealed and they were really upset chattering and scratching to get in.
    Never seen a rat in the neighborhood.
    MarjPinard
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,296
    If this is true, you'd think Ford would have learnt from the first time they used soy based plastics. They were making steering wheels from soy, before the petroleum based plastics started getting off the ground, and they were eaten in the open air cars. As Frank says, "You can't fix stupid" and that's how it seems most of the big corporations are run these days.
    Alan (California Radiant) Forbes Member Posts: 4,507
    edited March 2023
    This was on a steam shower control wire last month. Rats love nibbling on wire. On this one, I think they were trying to open up the hole to gain access to the house.
    Jamie Hall Member Posts: 26,182
    Which is why when I do or have done interior wiring it is always in BX cable... Not perfect, but better than plastic sheathed.
    CLambLong Beach Ed
  • JUGHNE
    As Jamie said, MC, AC, BX is much safer.
    As I slowly rewire in our main museum building it is all in MC or EMT.
    The building and contents are truly irreplaceable. And it is closed up for the winter with plenty of small creatures looking for a place to live with books, papers, and clothing etc.
  • ChrisJ
    A museum being a commercial space wouldn't MC or EMT be required by code?
    It has to do with the category of the building which has to do with height and size which has to do with how hard it would be to fight a fire in it.
  • JUGHNE
    edited March 2023
    Not necessarily, a lot of exceptions in the NEC....sometimes referred to as "The Book of Exceptions".
    Some of the required buildings are over 100 occupancy for sure, restaurants, any building over 3 stories etc.
    It is surprising for some buildings that do allow NM cable.
    Always ask AHJ if in doubt.
    JakeCK
  • JakeCK
    I love emt, nice n' clean looking when done well. But a pita when trying to run between joists and studs.
    CLamb
  • JakeCK
    edited March 2023
    I hate em. Before I had the corner of my garage rebuilt there was a small opening in the block that birds would nest in. That is until the squirrels decided to destroy the nest and move in. One day I noticed the tail in there, got the garden hose, shoved it in and went back to the house to let er' rip. That was one PO'd wet squirrel. Lots chattering at me from the peak of the garage. And when I had the hole fixed another(or maybe the same squirrel?) Was hanging around PO'd at me for weeks.
    They also destroy my pumpkins every year, and bird feeders.
    My grandmother actually won that battle using vaseline on the pole of her bird feeder. She laughed while sipping her coffee everytime she got to watch a squirrel run up the pole and then slide right on back down.
    MikeAmannMarjPinardMad Dog_2
  • I have a Squirrelinator trap that works very well except one day, I left it out overnight and caught a skunk and he let loose on me.
    I take the squirrels to a regional park near me and let the coyotes deal with them, but have always wondered what squirrel tastes like. Chicken?
    HVACNUTMad Dog_2
  • bburd
    bburd Member Posts: 1,173
    While preparing my grandmother's  house for sale I found an entire family of squirrels on the smoke shelf in the fireplace. Four long deceased and one recently deceased, which accounted for the smell…😵 I had to dismantle the damper mechanism to get them out. They had pulled open a corner of the wire guard at the top of the flue.
    Bburd
    MarjPinard
  • JUGHNE
    While doing utility line work about 30+ years ago, I came across a suicidal squirrel.
    We have the 3 wire secondary on separate insulators at each pole, top wire is neutral/ground with the 2 hots below.
    The squirrel has back legs locked on lower hot phase, front legs on upper hot phase (middle wire) and then his teeth on a bare #6 copper ground wire connected to the top neutral.
    He must have been there quite a while, only bones and hide intact, dry as a bone.
    He must have just grabbed all wires at the same time and was mad and bit the ground wire.
    This was only 240/120 volts. The higher voltages of 2400/4160 might have burst him into flames.
    And the event might trip out a fuse or breaker.
    That happens and then the flaming body torch falls down to the dry grass below starting a prairie fire.
    Many utilities install bird/squirrel guards in critical locations on the system to prevent this.
    It makes the Peta people happy, but the main advantage is for the utility.
    Solid_Fuel_ManJakeCKMad Dog_2
    edited March 2023
    This little guy chewed the insulation off the hot wire and then hopped over it onto the (grounded) water service, his belly and paws closing the circuit. I wonder if it blew the circuit breaker or fuse.
    Solid_Fuel_Man
  • JUGHNE
    With the cooked squirrel picture, the lower right plastic cap is a bird/squirrel guard as that is the 7200 connected to the lighting arrestor. Keeps them from direct contact with hot bolts. Probably still kill them but not shorting or fire involved.
    Alan's little guy must have liked the insulation on the knob & tube wires, which my squirrels did not chew on in my situation.
    archibald tuttleLong Beach Ed
  • bburd
    So now we know what happen to squirrels. But Natasha… What about moose? 😆
    Bburd
    kcoppCLamb
  • JakeCK
    More pictures of the squirrely damage:
    Solid_Fuel_ManMarjPinard
  • ChrisJ
    Better rip it all out and install heavy conduit
  • JakeCK
    Are you being facetious?
  • ChrisJ
    Mostly
  • archibald tuttle
    archibald tuttle Member Posts: 1,107
    I got this from a local utility buddy. This guy blew the 10A fuse and opened the cutout for a few blocks in town. 7200 volts.
    I left it as a thumbnail if anyone is sensitive to seeing it.
    sensitive . . . i love seeing that. a dead squirrel is a good squirrel. although i though that was 7.5 amp squirrel so it shouldn't have taken down the 10A fuse, although that's a slow blow . . .
    JakeCKSolid_Fuel_Man
    A caution about D-Con. It works, but not immediately. Unfortunately, if another animal, such is it might be your dog or cat, chances upon an animal, such as it might be a squirrel or rat or mouse, which is dying of D-Con and eats it, they may get enough of it themselves to kill them, or at least make them very ill. So do be careful where and how you use it That said, it is safer than some of the other rodenticides available.
    CLambMarjPinard
  • JakeCK
    Yea I don't have the desire to poison them. The issue is that there is a unlimited supply of squirrels. I'll be fighting that battle indefinitely.
    ethicalpaulMarjPinard
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,797
    We trap them in Have-a-heart traps and bring them to a neighboring community which needs more of them. It's a part time job for me.
    Solid_Fuel_ManMad Dog_2reggi
  • ChrisJ
    Is that legal in New York?
    Mad Dog_2
    ethicalpaul Member Posts: 7,762
    Sounds like another species we all know quite well...
    Mad Dog_2Alan (California Radiant) ForbesMikeAmannSolid_Fuel_Man
  • johnkern9068
    johnkern9068 Member Posts: 12
    edited April 2023
    You can blame corporate America but here’s the thing we’re talking about: squirrels, rats and several other animals chew on wire insulation, soy based or not. At a trailhead in Kings Canyon NP several vehicles had been driven onto blue tarps and the tarps gathered and tied off at the top. They looked like giant, poorly wrapped presents. Why? Marmots vs wiring harnesses.  Gophers do it too, plus polyethylene water tubing. (I have not seen chewing on PVC.) I recently looked at a used polyethylene kayak. It was in great shape. Wait a minute, what’s that damage on the bow? Did somebody run into something in this boat? An inspection revealed, you guessed it, tooth marks. What is the deal with critters and plastic?
    CLamb
  • Mad Dog_2
    My Friend's Father is an old Irish Farmer with electrical skills...and he spends his early morning hours zapping the squirrels that try to get up to the bird 🐦 feeder on a piece of 3/4" EMT that he can electrify with a switch he has at his desk overlooking the yard.  People are strange....Mad Dog
    Alan (California Radiant) ForbesMikeAmannreggiSolid_Fuel_Man
