Gas heating - Gas Valve or Circuit Board?
2»
    Jamie Hall Member Posts: 27,013
    Also check the pin fit on that Molex -- a loose fit of a pin in its socket can cause all kinds of weird problems.
  • Tim McElwain
    Tim McElwain Member Posts: 4,658
    You should never resolder any boards. There is a tremendous liability should anything go wrong. REPLACE THE BOARD!!!
  • highrollar420
    highrollar420 Member Posts: 2
    I see this thread was from awhile ago but did you double check your inducer motor started up? Not the blower motor
