Oil to propane conversation
gsierra14
Member Posts: 4
in Gas Heating
Hello everyone,
i just did a conversation from oil to propane and was wondering if anyone that has done one at their home what are you the draw back? I had an old oil boiler original to the house not efficient at all and converted to propane Combi boiler with 2- 120gal tanks. Had it for almost 2 months now. I’m looking for more of how often have you needed to have the tanks filled?
What was the cost of oil?
What is the cost of LP?
What's the make and model of the LP boiler?
I think you're in for a Suprise!0 -
In my area it works like this: At best LP will cost you the same or a bit more, at worst it will cost you considerably more.
LP prices vary a lot by region and supplier. If you have detailed records of how much oil you used in the past and current LP pricing we can see how you are doing.0 -
Too many variables to tell you how often you'll need to have the tanks filled -- it might be once a week, it might be once a year.
Depending on your local fuel prices, though, it will either cost about the same as the oil did -- or a lot more than the oil. If you are in a corn or grain growing state, you might break even.Br. Jamie, osb
You'll be saving a lot of fuel by virtue of replacing that old boiler (which sent too much of it's heat up the chimbley) to a modern boiler.gsierra14 said:Hello everyone,
But, 250 gallons of propane doesn't go very far, even with an efficient boiler. LP has a lot less BTU in it per gallon than a gallon of #2 heating oil (like 40% less), so even with the same boiler, you'll be using a lot more LP than heating oil. So your 250 gallons of LP is worth about 150 gallons of heating oil.
Without knowing the size of your house, the insulation of it, the size of your boiler, it wouldn't be possible to guess how often those tanks are likely to be filled, but I suspect it is often.
As far as cost, where I am in Connecticut today as I write this, heating oil is 3.37 per gallon and LP is 3.85 per gallon. Considering that LP has 40% less BTU than a gallon of #2 heating oil and cost about 15% more per gallon than oil, heating with LP is VERY expensive where I am.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
