Carbon monoxide near miss
Hard to imagine a leak that small putting out that much co1.
Must have been burning poorly aa well.
Also surprised that the building department didn't insist on detectors as per code
https://crestedbuttenews.com/2023/01/serious-cb-carbon-monoxide-incident-raises-concern/
Agree...In Summit country they will not give you a final inspection unless you have CO monitors.CBRob said:The new affordable housing project in Crested Butte, i think it's an oring or something?
Do you know which Make and Model has these issues?0 -
I've never regretted NCIS low level detector...throw away in 5 yrs although mine are 8yrs old. Super sensitive. Goes off when The old Durango warms up in driveway or the cooking gets a little crazy...Ive brought them away with us like Jim Davis always told us... save your life...you don't know whats not piped right in the motels mechanical room next to you... mad Dog1
Agent Leroy Jethro Gibbs appreciates your your positive feedback on NCIS Director, however can you clarify if you are referring to Director Vance or Director Shepard or the original Director MorrowMad Dog_2 said:I've never regretted NCIS low level detector...throw away in 5 yrs although mine are 8yrs old. Super sensitive. Goes off when The old Durango warms up in driveway or the cooking gets a little crazy...Ive brought them away with us like Jim Davis always told us... save your life...you don't know whats not piped right in the motels mechanical room next to you... mad Dog
2 -
That was a near hit!SlamDunk said:
😂0 -
Not sure what model it is.Derheatmeister said:The new affordable housing project in Crested Butte, i think it's an oring or something?
Agree...In Summit country they will not give you a final inspection unless you have CO monitors. Do you know which Make and Model has these issues?
Thought maybe one of you guys would know?
UL Listed detectors do not alarm until 70 PPM has been reached or exceeded for UL to 3 hours.CBRob said:
Thought maybe one of you guys would know?Low level alarms alarm at much lower PPM’s but don’t meet code!0 -
This is the boiler in question.
https://www.consumerreports.org/boilers/lochinvar-recalls-residential-condensing-boilers/0
