Wi-Fi Air quality sensor in the Boiler Room
guzzinerd
Member Posts: 423
As per the title, i installed a cheap $42 sensor between the boiler and 100 gallon gas water heater that sends a feed to an app on my phone. Curious if you guys feel this is enough to make sure things are running ok or should I get something else? The CO2 level goes up to 640 when it's been on a while.
P.s. i bought this before discovering this forum or would have asked beforehand.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Why would you want to know how much Carbon Dioxide is in the boiler room?0
Just general info.. shouldn't every boiler room have a CO2 reader?Long Beach Ed said:Why would you want to know how much Carbon Dioxide is in the boiler room?Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Just general info.. shouldn't every boiler room have a CO2 reader?guzzinerd said:Long Beach Ed said:Why would you want to know how much Carbon Dioxide is in the boiler room?
Are you thinking carbon monoxide? Carbon dioxide feeds plants.0 -
I think you are confusing carbon dioxide -- in normal quantities, quite harmless if not useful -- and carbon monoxide, which is not the same thing at all, and is, even in small quantities, harmful and can be quite easily lethal.
Your widget neither measures nor reports carbon monoxide -- and therefore is of little practical use.Br. Jamie, osb
Jamie Hall said:I think you are confusing carbon dioxide -- in normal quantities, quite harmless if not useful -- and carbon monoxide, which is not the same thing at all, and is, even in small quantities, harmful and can be quite easily lethal. Your widget neither measures nor reports carbon monoxide -- and therefore is of little practical use.
As dumb as i feel I'm glad i asked you guys. I did confuse CO with CO2. I'll return it and get a carbon monoxide reader.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
- 117 Geothermal
