thermostats in parallel
quack24
quack24 Member Posts: 74
was wondering if this would work
put a regular thermostat and this one https://jacksonsystems.com/product/55-degree-temporary-heating-construction-thermostat/ in parallel with each other to protect the building from freezing in case someone shuts the heat
    pecmsg Member Posts: 7,020
    If they shut off the heat how will it work?
    ethicalpaul Member Posts: 8,628
    If by "shuts the heat" you mean they turn down or off the main thermostat, then yes that would work. If they kill the power to the HVAC, as @pecmsg indicates, that won't work.
    mattmia2HomerJSmith
  • Motorapido
    Motorapido Member Posts: 314
    I use two thermostats, in parallel. The primary thermostat is a Honeywell Lyric wifi thermostat. I like the daily usage data and the ability to change the temperature remotely, from my phone. However, I live deep in the woods, where power outages are frequent, and despite having a whole-house generator, I still wanted an additional backup to make sure my pipes don't freeze. My heat source uses a millivolt gas valve, which functions without any external power, so it works during power outages. The millivolt thermostat that I connected in parallel with the wifi thermostat is a low-temperature model, going down to 40 degrees. I keep the millivolt thermostat set to 50. That way, if power goes out and my automatic whole-house generator fails to turn on, the no-power-needed millivolt thermostat ensures that the temperature won't fall below 50.
    The product in your link appears that it would work in the same method as any thermostat, so I don't see why you can't wire it in parallel with your primary thermostat to guarantee that the temperature will never fall below 50.
    searay26ratio
  • quack24
    thanks all
    when i said shuts the heat i meant turns it off from the thermostat
  • searay26
    searay26 Member Posts: 1
    This is exactly what I want to do at my cottage. For the same reasons but I don't have a back-up generator there. I installed a new battery only thermostat, just a 2 wire that controls the gas fireplace. I believe it works without power, (except for the fan) I also have a Honeywell wi-fi thermostat, along with a 24 vac transformer that I plan to use to power it. Thinking of wiring them in parallel and setting the battery operated thermostat at 50, while using the wi-fi to check temperature and change set point before arriving. I'm not good at wiring and was wondering how it was that you set up yours.
