Steam pipe insulation! Wondering if this is to close to the boiler exhaust
matt_spear
Member Posts: 2
From paper to metal exhaust is about 2 3/4 inches0
That should be fine. The Barometric draft control should be straightened up though.
Who ever did your last professional adjustment on the draft control did not get an accurate draft adjustment, and therefore your combustion adjustments can not be correct.
If you did a DIY chimney inspection and put it back that way, the combustion adjustments are now way off.Edward Young Retired
Code requires 6" clearance between single wall flue and combustible materials.0
Is Fiberglass insulation Combustable material?pedmec said:Code requires 6" clearance between single wall flue and combustible materials.
The paper YES
Easy solution
Cut the insulation back 6" from the vent.0
- 116 Geothermal
- 15.8K Strictly Steam
