Leaking external boiler pipe
Paulonion
Member Posts: 1
in Gas Heating
Hi. The pipe coming out of the back of my boiler to the external wall drips every time the boiler is turn on for the central heating. Is there a likely cause? Thanks
Is it a condensate drain for the boiler?
Unless you’re in a climate where freezing never occurs, no piping (including the drain) should ever be run on the exterior.Bob Boan
Is it connected to the pressure relief valve on the boiler?
If so you may have a faulty air expansion tank.
And note the comment about freezing.0
- 116 Geothermal
- 169 Indoor-Air Quality
