HelioPEX Alternate Kink Repair…1/2” Coupler?
Marvin007
Member Posts: 52
Is using a PEX A coupler on HelioPEX for a repair an acceptable way to cut a kink out and rejoin the 2 pieces of HelioPEX in a radiant floor loop?
The reason I ask, I have a kink in the center of one of my loops and I’ve tried to heat it up to remove it. There happens to be pressure on it and a twist in the pex pipe. When I heated it the twist caused the pex to turn a bit. I don’t feel confident that this repaired area wouldn’t leak in the future. The risk of a future leak is too costly and time consuming.
1
You gotta get the pressure off of it and the water out of it to repair it with a heat gun.Bob Boan
There is no water in the pex yet. New install. The pex is just going up. Here is what is looks like after a 2nd attempt. You can see the text is now straight. Would this pass an inspection or would it need to be replaced?
That pic happens to be right where a kitchen cabinet is on the upper floor. I was saving a few feet off pex in that loops in order to cut my total number of loops from 11 down to 10.
Thanks0 -
You would use the pex as is or would you rerun the pex? Just checking if your response had a typo in it (run /rerun?)ethicalpaul said:I'd run it0
