Reducing Manifold Gas Pressure
GMR
Member Posts: 3
in Gas Heating
Hello all,
Just wanted to reach out to the gas heating experts out there. What is your feeling about reducing the manifold pressure and adjusting the fan speed to achieve the proper temperature rise in order to reduce cycling?
I have a combustion analyser. I would not be increasing the airflow, I would decrease it in order to maintain the minimum recommended temperature rise.0
The system is Natural Gas0
What is your altitude? I have come across furnaces that needed to be de-rated and weren't. Lennox had furnaces that the service instructions suggesting altitude de-rating being done by reducing the manifold pressure.
All the registers should be open and temperature rise checked.
Sometimes the temperature thermodiscs that are in the safety circuit need replacing.0 -
