Vent Recommendation
Fmassarotto_9
Member Posts: 148
Can someone recommend a vent that would fit in this tight space, i would prefer not to disconnect the radiator if possible. I currently have a varivalve on this radiator and maid o mists on the other,
Maid O Mist won't fit there?
ethicalpaul said:Maid O Mist won't fit there?
nog enough clearance between the wall and where it threads,
How big is the radiator?All Steamed Up, Inc.
Consulting0 -
What's wrong with the Vari-vent you have in there now? They're have their faults, but they are pretty tiny.0
It looks like it's a 90 degree vent in the picture (to me). It must be tighter than it looks.
You could get an 1/8" elbow and coupling and a short and longer nipple and make an arrangement that would let you spin on a "straight vent" onto a "riser" that was rotated to in front of the radiator and then rotate it to vertical.NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 50 Industry Classes
