Vent Recommendation
Can someone recommend a vent that would fit in this tight space, i would prefer not to disconnect the radiator if possible. I currently have a varivalve on this radiator and maid o mists on the other,
    ethicalpaul Member Posts: 8,933
    Maid O Mist won't fit there?
  • Fmassarotto_9
    Fmassarotto_9 Member Posts: 148
    nog enough clearance between the wall and where it threads,
  • dabrakeman
    dabrakeman Member Posts: 1,020
    You just want to use a 90 degree angled vent rather than a straight vent like what it in your picture. 2" should be enough clearance between the wall and the threads including threading length for any right angled vent and a little less for a MoM.
    Steamhead Member Posts: 18,714
    How big is the radiator?
    Consulting
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    What's wrong with the Vari-vent you have in there now? They're have their faults, but they are pretty tiny.
    It looks like it's a 90 degree vent in the picture (to me). It must be tighter than it looks.
    You could get an 1/8" elbow and coupling and a short and longer nipple and make an arrangement that would let you spin on a "straight vent" onto a "riser" that was rotated to in front of the radiator and then rotate it to vertical.
    Long Beach Ed
