Replacing fan in a can
Enormo
Member Posts: 4
Hi everybody, I have a steam boiler that wouldn’t come on so I had a tech come out and take a look. It turns out that the fan in a can died so without air it wont let the boiler kick on. The company quoted me a big number to replace it so I’m trying to get a sense whether this is something a non-electrician like myself could/should tackle myself if I take a lot of pictures and swap everything out exactly as currently wired?
There should be an indoor relief damper on the intake pipe so you don't draw in too much air. What size is your boiler?0
The issue is it’s not drawing in any air at the moment. Boiler is 216k. Model KIN11LNC-LL20
Please remove the pricing from your post, we don't talk about money like that. It's one of the few rules we have, & it's an important one.0
I see you have at least 2 NG water heater tanks there.
Do they have enough combustion air?
Often they are interlocked with the Fan in a Can pressure switch.
Maybe the company assumed they were relying upon the Fan/Can.0 -
good eye - those are 2 hot water heaters, but I have only seen the fan turn on for the boiler while it was working.0
- 117 Geothermal
