efficiency
mikeGlosta
Member Posts: 5
in Oil Heating
I have well mcclain oil burner hot water- old old old. Efficiency at 71pc. I can't afford a new burner right now. What makes the burner so inefficient? Can a technician raise it to 80 pc. I can sent pics with specs if necessary.
Thanks
Maybe -- but you will need a good one. It needs to be thoroughly cleaned. The combustion chamber needs to be carefully examined and any firebrick which is missing or damaged replaced. The technician should check and see if any baffles in the gas path are missing or out of place. Then he will need to check the combustion, paying particular attention to the flame pattern and adequacy (there is no guarantee that the nozzle which is in there is even close to right, nor at the correct pressure), and then adjust for correct draughts and zero smoke.
Does it take time? Yes, probably the better part of a day if it hasn't been done in the last year or two. Is it worth it? Yes.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
Should be doing better than that-properly cleaned and set up correctly. High draft, high excess air kills efficiency, as does underfiring.
Best to get a tech in there who knows what they are doing.
Let’s see some pictures.
steve0 -
mikeGlosta said:I have well mcclain oil burner hot water- old old old. Efficiency at 71pc. I can't afford a new burner right now. What makes the burner so inefficient? Can a technician raise it to 80 pc. I can sent pics with specs if necessary.Thanks0
Would these pics give more information?
Were you there watching everything while the cleaning/servicing was happening?0
Ed and Jamie are right. That is a modern boiler which is capable of better work. It's a big job to clean a boiler, check and set up the firing and properly adjust combustion. I don't think 80% would be unreasonable to expect. Those stack temperatures say the boiler's probably dirty.0
I don't know what was done. I paid for a cleaning.
Then you need to be more involved with YOUR heating system.mikeGlosta said:I don't know what was done. I paid for a cleaning.
@mikeGlosta unfortunately a lot of service companys don't give a dam. In and out change the nozzle and filter and that's it.
I think the boiler is dirty and needs a good cleaning0 -
Yes,
When you hire a professional to do a job you need to be more involved..........
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
That is from May..Fuel line should be more of a concern than Effcy'.0
The internal pressure drop of oil equipment when firing correctly and clean is -.02" difference. If it is dirty the overfire would be less and the difference greater. If it is underfired the difference would be less, which is the case here. Of course that could be because it is dirty and the technician did that to save time.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
