Radiator bleed valve replacement question
hockeyman70s
Member Posts: 18
Hi all. I have a radiator bleed valve screw that keeps turning and turning but won’t tighten down (leaking). Afraid that if I keep going it will sheer off. Do I have to drain the whole system to replace. Really hoping not to as I just did this but there is no way to isolate. Think I could get away with having the new one ready to go and swapping out under pressure? Thanks 0
Only if you wanna get drenched.
My able-bodied helper thought he could make a command decision to do that last week and went home soaked from head to toe.
I think the worst part was him screaming for about 20 minutes to get the pressure off of the system as he could not hold it back with his thumb any longer.
Do you know how long it takes to drain 200 gallons?Bob Boan
you should be able to lower the boiler pressure back down to 0 without letting air in,
IF there are no auto vents up high,
then, yeah, a hot swap could work,
have tape or paste on the vent threads first, and expect some slight spillage,
known to beat dead horses0 -
@mattmia2 thanks, I’m hoping to get away with it. As a non plumber the reducing “ell” and “all” and reducer is that the elbow or something else? Are these something universal or need to be compared to what is there? Thanks0
@mattmia2 disregard- got them separated and replaced without issue. Thank you for consistently being a huge help. Saved my bacon!0
Ell is short for elbow. Autocorrect made "ell" "all" the second time i typed it.
That elbow is an elbow and reducer in one fitting that reduces the it looks like 1/2" tapping on the convector to probably 1/4" then a 1/4" to 1/8" bushing reduces the elbow to 1/8" for the coin key vent valve. There are lots of combinations of fittings that would get you there.1
