Mechanical/Saddle Tee?
TonKa
Member Posts: 111
It occured to me a mechanical tee like what is used on sprinkler systems could be a simple way to add a branch off a steam main instead of welding a thredolet or cutting the pipe and threading for a standard fitting. The gasket would be no different than what would be used for a flange.
It seems like it would save time. Is this just another crazy idea or have others tried this?
Is it rated for steam and steam temps?0
Easier way is Megapress for steamTonKa said:It occured to me a mechanical tee like what is used on sprinkler systems could be a simple way to add a branch off a steam main instead of welding a thread-o-let or cutting the pipe and threading for a standard fitting. The gasket would be no different than what would be used for a flange.It seems like it would save time. Is this just another crazy idea or have others tried this?1 -
gasket is not likely rated for steam0
The Submittal states this about the gaskets:( _ ) Grade “E” EPDM (Green color code)
-40°F to 230°F (Service Temperature Range)(-40°C to 110°C)
Recommended for water service, diluted acids, alkalies solutions,
oil-free air and many chemical services.
NOT FOR USE IN PETROLEUM APPLICATIONS.
( _ ) Grade “EP” EPDM (Green and Red color code)
-40°F to 250°F (Service Temperature Range)(-40°C to 121°C)
oil-free air and many other chemical services.
Does steam qualify as "many other chemical services"? Since water is inert (when it comes to chemical compounds) I would think that this product would be just fine for steam. Since we are all talking about Steam at less than 3 PSI in most systems, I believe the gasket that is rated for 250° should stand up to the temperature just fine.
But there are inspectors that will fail you because you can't prove to them in writing that this is an acceptable use. ... Dah... it don't say STEAM... If that matters in this caseEdward Young Retired
I have done a lot of Vic on hot water.
Whatever they rate their gaskets at is false. They may rate their gaskets at 250 "newer quick vic couplings" and at 230 for the older stuff.
But in my experience if you run at 200 withing a couple of years the gaskets dry out and lose their flexibility then shut the system down and when it cools you will have a rain shower.
We did use Vic on a temp steam line and it worked ok but wasn't in service that long1 -
- 117 Geothermal
