Bucket for draining steam boiler water
zoulas
Member Posts: 29
Garden hose?0
plastic. a dishpan can be handy where you don't have enough height for a bucket.0
So you are suggesting a plastic bucket? It need to hold approximately 2 gallons.0
Yes plastic
why are you removing water and refilling with new?
To remove the rusty water. Isn't this standard practice? It's a steam boiler. Aren't you supposed to remove some water on a weekly basis? I have been doing this for the past 30 years.0
Yes, you are -- from the low water cutoff if you have a float type. I use an ordinary 5 gallon plastic wash bucket until it gives up, then get another one...Br. Jamie, osb
A float type low water cutout needs to be blown down regularly.0
Maybe they sold you a small garbage can instead of a bucket. If it was sold as a bucket I'd return it. Any bucket or pail should work as long as it doesn't melt.zoulas said:Any recommendations, I just purchased a high quality galvanized bucket from Home Depot and on the third use it leaked at the seams.
Just to reiterate what’s been said. The only thing you drain on a weekly basis is if you have a float type now water cut off. If you have a probe type you shouldn’t drain anything on a weekly basis.
Picture of float type attached for reference.
LoL.. I read your review...I don't know if the mfg. will respond but I agree with others as far as returning it to HD as it obviously isn't water tightzoulas said:Any recommendations, I just purchased a high quality galvanized bucket from Home Depot and on the third use it leaked at the seams.
I use one of those thick Rubbermaid square pails or a empty 5 gallon joint compound or paint container.. they're thicker I think than than the $3.99 cleaning pails and when you you're carrying it full of hot water from the boiler it doesn't feel like it's getting squishy from the plastic softening..
Just my opinionOne way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
Just my opinion0 -
@mattmia2 Look again at the 3 star reviewers post via the link above to the pail at HD...I agree with the others HERE to return it..I wouldn't wait to hear from the Mfg ....
You bought a Chinese bucket? And it leaked? Bwahahahaa!
Oddly enough I bought an American made galvanized oil can with flexible metal spout and it leaked all over since day one and after a few months the spout split in half.
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
