Base-ray Baseboard Connections
quiptech
Member Posts: 2
Hi, I am in the process of doing some remodeling that includes removing and reinstalling a Base-ray baseboard heater. I have checked the manufacturer's I/O manual and it calls for the supply to be connected to the bottom connection and the return to the top. The existing installation has the supply and the return on the bottom connections. I plan on correcting the baseboard that is involved with the remodel according to the I/O manual. But as you can guess there are several other heaters all connected just across the bottom. Does anyone know how inefficient this will make my system with these incorrect connections? The system is a mono-flo loop if this plays into all this. Thanks
The biggest difference that I can see is that the recommended connection is a lot easier to get the air out of. And on a monoflo that's always a problem. Once they are operating -- shouldn't be much difference.Br. Jamie, osb
Hi Jamie, The less that I have to touch on these old baseboards the better. I am already concerned about separating the sections by accident. So only disconnecting and reconnecting the plumbing is good. Thanks for your response Jamie.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
