Toto Toilets No Longer Flushing Properly
Yes this is a real "thing." I have an Am. Standard Cadet. Every 5 years or so, I have that same build-up in the toilet's flush way. I empty the bowl COMPLETELY (sponge) and then fill just the trap with "Sizzle" which I believe is muriatic (or dilute hydrochloric) acid. It "sizzles" and fumes and foams! And...it completely cleans out the trap of any adhering build-up. The toilet then flushes...as if it were new.1
I’d try SizzleBob "hot rod" Rohr
Would any of these WC's been used by those who follow the motto: If it is yellow....let it mellow......if brown...flush it down.
Knew of a 3" DWV copper line, for a WC, rotting out on the bottom from this water conservation method.0 -
I have a friend telling me about another product, EdFred’s Cling’N’Clean. He used to be the Toto rep. out West here, so I trust him.I never thought I’d become so well versed in cleaning products.So many products, so little time.Maybe water quality ... or the owners need a urine testOur water quality is pretty good here. Very low in dissolved solids.As far as suggesting a urine test, I might get some long, furtive sideways glances as the customer wonders if he’s in his doctor’s office or in his bathroom. I’ve seen that when I suggest eating more roughage.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
I second the idea that these people need to visit the doctor...
I've heard of this with public urinals but a regular toilet?0 -
it it’s all the California wine consumption🥳Bob "hot rod" Rohr
I'm a bit confused how it could even be remotely related to someone's urine if it's not expected to sit in there very long. It's an issue with urinals due to people not flushing and or poor flush quality. No?
If it's only in there for a short period and the trap is occupied by water 99% of the time..........
I vote improper use of fixture (not flushing).
Ejector hole can also become obstructed. Some warm water in tank might help.
Often a brush can clean out build up.0 -
Hello,
1.28 from 4 or 5 gpf... that has saved a lot of water for me.... if you have well water.... no issues with flushing and been working well for years... Here is some info from epa... https://www.epa.gov/watersense/residential-toilets
Unless I have my teen age kid who eat alot thus far hasn't complained..
If he did... I would have a say and ask him to eat more fibervegs and fruits!! It always seems to work with flushing.... Unless it may be our former president that clogs toilets with flushing National Security documents
Best!1 -
LS123 said:
Hello,
Best!
Luckily I don't think I need an EPA website to tell me how much water is saved between a 1.6 and a 5 gal per flush toilet.
Sorry... Joke aside .... If you have checked the internal components, if the are in working order, then you should be getting the toilet to flush at 1.28 gpf as these toilets been tested for a while (years) and been in production for a while... when toilets were replaced, the pipes that connected to the toilets had to be cleaned for years of built up stuff in them.
I am wondering if the toilet that dont flush may have some kind of built up or blockage.... it seems to me based on experience... toilets on second and third floor seems to work better when flushing at 1.28 gpf than first floor. I am assuming gravity helps second and 3 rd floor....
@ChrisJ .. you are a pro and you dont need EPA docs... links... totally understand...
Links etc was there for general info.... not specifically for you.... Having lived on city water in CT and no worries about water... living off a water well has help me understand and conserve lot more...Best!0 -
While I like to think I'm an expert at using a toilet these days I don't think I've reached pro status yet.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
maybe the municipality has somehow let the water quality change?
years ago I had a modern single handle delta t-s valve slow up on me. I'm like 'wow, that's a first'. It happened after i changed a water heater, and i ran the air though the Delta
>>that was the last time i ever did that! I had done this hundreds of times in the previous two decades
Anyway, I ran some Clobber through the valve with a trans pump, i think 50/50, i don't recall at this point. I used a bike tube to get the solution from the valve body back to the bucket. presto--it worked. The one and only time i have even seen this. it happened to be my own apartment-- the tenant eventually moved, which allowed me the time to scratch my head and deal with it.1 -
@LS123 ok cool, not sure if the common man runs Sulfuric Acid through their plumbing valves, but I just do whatever i do most of the time. Yes, it's main intent is drain lines.1
I wonder if this is corrosion inhibitors added to the water to reduce the leaching of lead and copper building up in the passages.
Probably any acid will remove it, some may take longer than others, some may damage the porcelain.
Even very old toilets with 5 gal tanks don't usually completely empty the tank during a normal flush, so those did not use as much water as the tank held.ChrisJ said:
Luckily I don't think I need an EPA website to tell me how much water is saved between a 1.6 and a 5 gal per flush toilet.1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
