Source for Eccentric Bushings?
dennis53
Member Posts: 68
I'm looking for some eccentric bushings for use in setting up a new run of used radiators. 2" x 1.25" and also 1.5" x 1.25". Anyone have a source who will ship to Vermont? Many thanks,
Dennis
Dennis
Dennis
Granger
Zoro
Furgason
try searching couplings0 -
Another option is to use a reducing ell or street ell or reduce it vertically0
Searching for ECCENTRIC REDUCING COUPLINGS may give better results. Its easier to get an eccentric reduction in a horizontal run of piping with an eccentric coupling than with a bushing.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
I have not seen eccentric bushing in a while. couplings are available but $$$. Reducing with an elbow as @mattmia2 is the simplest and best way if you can do it0
Thank you for all the suggestions. I was hoping to use bushings, but will probably end up going with couplings unless I can find a used radiator shop that might have some old bushings. Reducing on the vertical is not a possibility in this situation. Thanks again for the suggestions,
Dennis
Dennis0
- 117 Geothermal
