Source for Eccentric Bushings?
I'm looking for some eccentric bushings for use in setting up a new run of used radiators. 2" x 1.25" and also 1.5" x 1.25". Anyone have a source who will ship to Vermont? Many thanks,
Dennis
Dennis
    pecmsg Member Posts: 7,039
    Granger
    Zoro
    Furgason
    try searching couplings
    mattmia2 Member Posts: 16,644
    Another option is to use a reducing ell or street ell or reduce it vertically
  • Pumpguy
    Pumpguy Member Posts: 799
    Searching for ECCENTRIC REDUCING COUPLINGS may give better results. Its easier to get an eccentric reduction in a horizontal run of piping with an eccentric coupling than with a bushing.
    EdTheHeaterMan Member Posts: 12,128
    I have an eccentric Aunt Dorothy, perhaps she has some bushings in her pantry! I'll call and ask her. ...Will get back to you on this!
    ttekushan_3PC7060luketheplumber
    EBEBRATT-Ed Member Posts: 20,137
    I have not seen eccentric bushing in a while. couplings are available but $$$. Reducing with an elbow as @mattmia2 is the simplest and best way if you can do it
  • dennis53
    dennis53 Member Posts: 68
    Thank you for all the suggestions. I was hoping to use bushings, but will probably end up going with couplings unless I can find a used radiator shop that might have some old bushings. Reducing on the vertical is not a possibility in this situation. Thanks again for the suggestions,
    Dennis
    Dennis
