Hot Water Maintenance (HWM) cable?
JohnNY
Member Posts: 3,358
Hello all,
I'm exploring options to provide a HWM product on a job. If you've used one you like, please let me know which it is. I'm getting higher prices than expected and want to do my due diligence.
Very best,
John
Very best,
John
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Like this: https://www.chromalox.com/en/catalog/heat-trace/industrial-heat-trace-cables/hot-water-maintenance-heat-trace/hwm-hot-water-maintenance-heat-trace-cable
No one? Bleh.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
I use pipe heating cables from time to time, but not for hot water maintenance. Just to keep the durned pipes from freezing.Br. Jamie, osb
I didn't even know such a thing existed. Seems like re circulation is far less expensive in the long run.0
Hi @JohnNY , could you give us a bit more detail about the system and what you're trying to accomplish? Electrically heating poorly insulated water can work, but will cost far more in operating costs than other methods, like demand recirculation. If it's just for freeze protection, that's a different matter.
Yours, Larry0 -
The HWM cable was an unfamiliar term to me. I have never seen it used as a domestic hot water heater before.
I have seen heat traces used to keep pipes from freezing to keeping pipes hot so flowing grease or chocolate keeps flowing. It makes good sense to keep the water hot rather than circulate it back or having multiple hot water heaters thru out a building. It is a copper saver. I like that idea. Making it maintenance friendly for the next guy would be cool! I guess you would need an expansion tank(s) on that line.1 -
In this case it’s being used on an extended run to a grease interceptor. The warmed insulated drain pipe will keep the grease from congealing before it can be separated and discarded.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
It is commonly used in food processing facilities. Try starting here.
https://www.drexan.com/trace-heating-solutions/food-processing
https://www.drexan.com/pdfs/2015-march/HD101004-2 - PipeGuard Hot - Rev6 draft kp.pdf1 -
We have done heat tracing on both hydraulic lines at a wood processing facility and chemical lines at a paper mill in the past, but we always used a thermostatic control to cycle it. I think it was an unregulated heat trace we got from McMaster. The product you linked to looks a lot easier. I’d be interested to know how it is to work with.0
I used to buy the self-regulating stuff from Grainger. Ray Chem makes it. Cut it to whatever length you need. Put an end cap on it and hook the other end up to the power.
Depending on the environment and temperature you run it along the pipe or spiral wrap it around the pipe depending on pipe size and how much heat you need1 -
I did a job at a college with HWM cable. RayChem branded, did it 12 years ago. I don't have the contract for the building so I have no idea if they have had long term issues with it or what it costs to run.
Self regulating, connected to the BMS and run on an occupancy schedule. There was miles of it, all covered with standard fiberglass pipe insulation and above lots of other mechanicals in the ceiling.
Seems a recirculating loop properly pumped would have been better long term?
I have used RayChem self regulating heat trace on several roof drain and gutter projects with a very good track record actually. Buy it is very expensive.
You can get it in 120, and 240 volt. And several watt/foot variations.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I'll check out Ray Chem. Thank you.Solid_Fuel_Man said:I did a job at a college with HWM cable. RayChem branded, did it 12 years ago. I don't have the contract for the building so I have no idea if they have had long term issues with it or what it costs to run.
@pecmsg Yes. This is a project in Manhattan and it's not completely uncommon. Working here where access to the building and its mechanical systems is often limited and always costly, sometimes, the way to get instant hot water is to wrap a hot wire around the pipe, operating costs be damned. Processes here are sometimes difficult to explain to those who work elsewhere.
Classes1
- 50 Industry Classes
