Nightmare with children's showers
What I might suggest -- besides parental control, which I'm sure you've tried -- depends a little on whether you are trying to save water or energy -- or both. A very effective approach if it more on the energy side is to limit the amount of hot water available with a timer. I found this: https://www.showertimers.net/?msclkid=b9ad671b8c3814c90e3c05871f3581cd but I haven't tried it. You'd have to put it somewhere where it couldn't be fiddled. Even more effective would be to plumb the shower hot water with an undersized water heater -- say something like this: https://www.lowes.com/pd/Eccotemp-Mini-Storage-Tank-Series-7-Gallon-Regular-5-year-Limited-1440-Watt-1-Element-Point-of-Use-Electric-Water-Heater/1001263582. Turned up to high, that would give you about a 5 minute shower with low flow heads.Br. Jamie, osb
How about something that measures the time with shower running (thermal sensor on pipe as trigger), and then deduct a reasonable "fee" from their allowance ?
Good life lesson on how the world works, and a bit of cost recovery for the bill payer.
Currently in building maintenance.0 -
Some day you can visit them in their first home.
When you do, remember to walk in without saying hello, turn on all the lights, open all the kitchen cabinet doors and drawers, leave the toiler seats up (for daughters only) adjust the thermostat higher, (colder in the summer). look in all the rooms and maybe even open a window or two. Then, leave out the back door without closing it, get in your car and go home. In about a half hour, send a text "Nice House"
I know, I did that to my daughter the first time I saw her new home. I lived about 90 minutes away and it was worth the drive.
6 -
Maybe this is a pick your battles situation.0
@hot_rod has it right, just turn down the temp on water heater. They’ll get after it run out of hot water in 10 minutes.Another good tip in to install a Leviton moisture sensing fan control switch. Much better than banging on door telling them to turn on the fan!0
I've never run ours on full-auto mode, but one press of the button and it runs until either the timer expires or longer if the humidity is above trigger point. I trained my young monkey to press the button when he starts the water, so that part seems to be working (small victories).PC7060 said:... install a Leviton moisture sensing fan control switch.
I was thinking on full-auto, it would just run all the time during humid days ?
Currently in building maintenance.1 -
Dave Carpentier said:
We really don’t have a problem with that. Our house is air conditioned so that keeps humidity under control but even when the AC is not honestly never been an issue. I typically just run it in the settings as it comes from the factory and performance is excellent.
It is important to have it at like 50 inches up typical switch height. I have in the side of a counter at around 3 foot and it is slow to respond since the steam/moisture build from top down.
That certainly no surprise for the steam heads on the site!0 -
My father-in-law used to shut the hot water off on my wife when she was a kid. It was an effective technique because she still takes short showers to this day.0
DJD775 said:My father-in-law used to shut the hot water off on my wife when she was a kid. It was an effective technique because she still takes short showers to this day.0
Hi, Working on hot water stuff for years got me lots of questions along these lines. My response became "Think of who will be taking care of you in your old age." You don't want them thinking about those times back when they were kids, when you turned off the shower water! ... Low flow showerheads reduced the tension quite a lot.
Yours, Larry4 -
Agree, that’s why I’m an advocate of the auto fans switch and setting the hot water heater down a bit. Achieve the goal with a minimum of fuss0
@CYBORG21
If you can measure the water use (timing a 5-gallon bucket fill works well). Describe (or take pictures) of your water heating system and share your utility costs (or a picture of your bill) for both the fuel and water, we can help you quantify the costs.
I think "nightmare" is a pretty extreme reaction to kids spending a long time in the shower. After all, they are home, safe, and VERY clean. Things could be worse...."If you can't explain it simply, you don't understand it well enough"
Albert Einstein5
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
