Actual Performance of Cold Climate Heat Pump in Upstate NY
My home has a 1980s vintage heat pump with gas backup that continues to work well. We don't use the heat pump for heat because I believe at the time of manufacture they were not very efficient below 40F.
I also own a nearly 100 year old converted 2 family that has a very well working steam system. Thanks to the help on HH and Charlie Garrity in the Springfield, MA area.
I have been interested in cold climate units and several years ago, I read about some studies in them.
Occasionally, when I go to the Orange store, I get asked if I am interested in the more modern units.
My first question is always, "What do you do when the temperature gets well below zero?"
I have gotten answers like,
"Wait until it warms up.", which doesn't work for my house or for my rental property.
"These are not for whole houses, just things like add-ons."
"Keep your rental house steam system as a backup.", which is not very satisfying, since the purpose of the change would be to get rid of the steam system.
Are there in existence any systems that can serve a whole house, and how do they deal with colder than -15F conditions?
  • In_New_England
    In_New_England Member Posts: 146
    I looked into heat pumps to move off oil heat hot water baseboard near Boston. My takeaways were
    Tight house needed
    Fossil fuel or electric strip backup needed
    Annoying if you don't have central air
    I have colleagues who swear by the Mitsubishi hyper heat, but they all have backup systems and newer construction.
    Jamie Hall Member Posts: 26,072
    There are a number of threads on this sort of thing, @SteamingatMohawk , but I'll give a shot a summarizing. First, heat pump systems certainly can heat a whole house, if the situation is right. Just a matter of sizing and source temperatures.
    Which is the second question: at the present time, so far as I know, there are no air to air heat pumps which can manage with a source temperature of -15, although I believe that some progress is being made. Somewhere around 5 to 10 above seems to be the reasonable lower limit for air to air heat pumps without resistance backup at the moment Now: if you go to ground source heat pumps, that's a different story, since there the source temperatures are high -- 40 to 50 -- as the source is either a buried grid (below frost level) or deep wells.
    Then the next question is how does the heat get into the house? Heat pumps -- of any source -- top out at around 130 for hot water units, and a bit less than that for forced air. This would mean that while you could get rid of your steam system and use a ground source heat pump, either forced air or hot water, it would be a complete rework of the heating in the house. There would literally nothing, except possibly the thermostat, that you could reuse (not even the power circuit: your steam system takes 15 amps at 120 tops, the heat pump would be looking for 50 to 100 amps at 240)
    In_New_Englandmrblint
  • leonz
    leonz Member Posts: 1,544
    The Northeast Energy News highlighted Ithaca, New York today and its craziness in converting the businesses and homes in the city limits to heat pumps with its desire to become carbon neutral.
    They are finding its going to be extremely difficult to do especially with how much it is going to cost the home and business owner.
    The other thing is heating a home in periods of near zero weather is extremely difficult with even new air to air heat pumps and we have long periods of low temperatures to live with in some winters.
  • GW
    GW Member Posts: 4,992
    Most Contractors are simply managers of physical work, mental energy, risk and reward. Then sprinkle in a couple dozen more factors and Poof- you have an hvac guy
    The older the house, the less jubilant contractors are to stick their neck out on the line (all Heat Pump with no backup): more risk for the same reward. If they have no work, they’ll probably stick their neck out a little bit further. If they are slammed- well you get the point
    The time needed properly calculate this situation is a bit. If you throw the question out there like you’re trying to corner the fella at Big Orange, you may get a similar response.
    If the house has been modernized, that’s a totally different conversation
    Virtually none of these people selling HVAC have a blower door. If the house is old and leaky, it’s a bit of a waste of everybody’s time
    One of my simple go-to sayings is, “we can add more heat or you can reduce heat loss” (Either option is perfectly wonderful)
    Your 1980s house seems more doable
    Good luck with the heat pump install; they are all the rage here in Massachusetts. Wicked rebates this year
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    GGrossBig Ed_4
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,062
    Your comments all pretty much match my impression of the state of the art.
    The apartment lot is only 40 x 140 with a 6 car side load parking lot and 25 x 50 building on it. I'm very skeptical of using ground source there and there isn't enough land available for horizontal, except going under the parking lot, then repaving $$$$(heat gain from the asphalt could be a help). Keeping the steam system and letting the tenants use window units has been the way of operating and no one complains about AC. As I said earlier, HH and Charlie have been great resources to get my steam system working properly.
    My house is 500+ feet from the road (long neck funnel shape) so I could run lines but that part of the lot is only 41 feet wide with a 10 foot wide driveway. There is probably room for vertical somewhere else on the 2.28 acre lot. I have a backhoe, so that could be a fun project as long as I don't hit water, gas, cable or power lines.
    All that being said, I am not interested in a backup separate system and I think electric backup would be cost prohibitive. The only minor issue with my existing home system is it is not zoned (wasn't considered when the house was built in 1987).
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,194
    @SteamingatMohawk for your house, geothermal is a tough sell. The increased loop expense is hard to recoup as air source heat pumps have closed the efficiency gap (sometimes even exceeding ground source applications in practice). Since it’s ducted, the most obvious solution is air source heat pump + electric or fossil backup. Will electric backup be expensive to operate at -15? Of course. Will it matter? Probably not. Pretty vanilla setup all things considered.
  • fentonc
    fentonc Member Posts: 305
    @SteamingatMohawk - Do you have hourly temperature bin data for your location? That would let you quantify the operating cost of electric backup to see how prohibitive it would actually be. I was genuinely surprised how few very cold hours my location experienced when I measured it, compared to how I perceived it. It got down to about 4F this year (for about 2 hours), and there were 3 total days with an average temperature of less than 15F. You can probably make a very good estimate of the actual operating cost using available data.
  • leonz
    If you do not already have a double drop header on your boiler it would save you a lot of money and gas to have one installed to make more dry steam faster and reduce your gas consumption
    MY brothers have a brood herd of Mitsubishi and Carrier heat pumps in their rental and condo units and they do not do well in near zero / below zero conditions and require the tenants/owners to use supplemental heat.
    Vertical geothermal using the semi open loop method will work as long as a large diameter bore hole-14 inches in diameter is mud drilled and 12 inch steel casing in high strength sand mix cement is set to the final depth and the water in the well pipe and the captive well water is pumped with a jet pump.
    Using a jet pump eliminates the need for a submersible pump in the well and reduces the chance of lightning destroying a jet pump to almost zero.
    Every 100 feet of depth will provide you with one ton of heating and cooling power until you get near 1,000 feet in depth where the rock begins to warm up.
    If a geothermal driller suggests using a well with thermally enhanced grout for a heat pump walk away!!!!!!!!!!!!!!!!!!
    I say this because these grouts contain clay in them and clay is an insulator.
  • GW
    Leonz, clay is the best- it’s a conductor. You want conductivity in a loop. Sand is the worst.
    That’s why geothermal has up and down reviews- the loop performance will make or break the system
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • SteamingatMohawk
    edited June 2022
    @leonz Great suggestion, but the double drop header is not available, because the boiler has only one 3" steam tapping. The pipe comes straight up about a foot, turns right for about 2 feet, then turns back another 1-1/2 feet to connect to 2 vertical mains to the front, then rear of the house.
    @fentonc I don't have any digital recording capability. I use a Honeywell wireless thermostat with WiFi capability and the WiFi adapter so I can monitor the system status with my cell phone. It wasn't cheap, but I have only one thermostat for the entire house (90+ year old 2 family converted to 4 units) and the thermostat is the furthest away from the boiler. I also like it because I can relocate the thermostat anywhere without doing any wiring.
    Having the WiFi capability makes it so I can turn the heat on and off without leaving the basement and going through 4 door, 3 of them locked. Sorry for the side comment, but anyone thinking about changing their single hard wired thermostat, might be interested in what I did.
    Thanks to both of you.
  • fentonc
    Oh, I just meant look it up for your location (or somewhere close enough). I did actually measure mine, but I really was surprised how much warmer it was than what I would have guessed if asked previously.
  • leonz
    A poorly designed and implemented geothermal system will not heat or cool very well at all.
    I use firebrick as the best negative example as the clay used make it a firebrick holds heat and sheds it very slowly which is something you do not want in a geothermal system using the closed loop method of heating and cooling as you want the heat to migrate to the cold ground and mason sand will take the heat and shed it into the surrounding rock strata.
    Using fine mason sand in an uncased well would work well as its exposed to the sediment and rock in the bore hole but a semi open loop or open loop method of geothermal heat exchange is better UNLESS you have a source of water like a river or lake that is unaffected byu deep freezing and has perpetual flow that can be used.
    This is why I suggested using a large diameter well casing (12") sealed at the bottom with a pipe cap or pipe plug if collared casing pipe is used and concrete ballast for a sealed semi open loop method of heat exchange as the warm water sinks to the bottom over time and becomes chilled.
    Using a 2 pipe jet pump would use the cold water in the well to drive the dense cold water in the base of the well to the surface to pass through the heat pump plumbing and either chill or heat the living space/workspace.
    If the sealed well was in an insulated pump shed or well pit you could avoid the use of a below ground sanitary well seal and use a 2 pipe sealed/gasketed well cap.
    If a three hundred foot well is drilled and 12 inch casing is used you could have the benefit of 5.875 gallons per foot of depth. If you have 280 feet of water column in a 12 inch casing you could make use of 1,645 gallons of water in a sealed water column to use in geothermal heat exchange.
    A standard 6 inch cased well will only give you 420 gallons of captive water to use in a sealed water column that is 280 feet in depth.
    The drilling of multiple wells in sealed loops with "geothermal grout" ugh, is a waste of money when single captive water well could do the same work in my opinion.
  • _doc_
    _doc_ Member Posts: 2
    In April of 2024 we decided to replace the 1954 Lennox gas forced air furnace with a more efficient unit. It was running as quiet as ever, but even we knew its efficiency had to be poor. And besides-we thought it would be nice to do our small part for the environment, understanding full well that the electric infrastructure in NYS is something akin to "the cart before the horse". But we did it anyway. Our home is a 2 story, 1935 brick colonial revival; 1500 sq ft.; 2 window AC units in the warm weather; furnace when the chill hits.
    What shook out of all our research was a cold climate heat pump (HP) with an aux gas forced air furnace. Though the HP is rated down to -5F, but we set the x-over temperature at 20F to help with overall efficiency. A few electrical upgrades and we were ready to go. With the warm weather arriving, the HP did a nice job of keeping the house cool. As we transitioned into the cooler fall, we let the HP continue to work at the "Auto" setting to cool and heat the house.
    I became suspicious of the gas/electric bills about September; that the actual usage seemed higher. And the bills were running about $130/mo higher. So in November I started an experiment- the HP only for all our needs; 24/7; no furnace. We ran that way November and January. December and February were the furnace only.
    Now- there are a host of other factors that would influence the final bill each month. But despite all that, the bottom line is that while the HP may indeed be efficient, the run cost is to high for this particular house. It seemed to run constantly. Bills for December and February (furnace-only months) were much closer to normal, if not less than previous billing cycles.
    The two heat sources are obviously different and the "feel" of the heat is different. It's hard to explain. The HP works diligently to keep the room temp consistent (+0F, -1F), whereas the furnace is more of a warm "blast" of air that dissipates over time (+/-1F) and the cycle starts again. We'll continue to experiment with the two systems, but for now it's the furnace for heat and the HP is a yard ornament that will only be called upon to cool the house. Would very much like to hear your experience with similar systems. Thx.
  • DCContrarian
    DCContrarian Member Posts: 1,125
    edited April 23
    The answer is the electricity usage depends on the house, the equipment and the climate; the economics depend on the price of electricity vs. competing fuels.
    I recommend this post which lays out the full process of making a comparison:
    https://www.greenbuildingadvisor.com/question/how-to-model-and-predict-electricity-usage-for-a-heat-pump
  • psb75
    psb75 Member Posts: 1,048
    leonz: "…warm water sinks to the bottom over time and becomes chilled." I don't believe this is what happens in a bored well. Warm water does not ever sink. It is lighter than cold water. It wants to stay on top. This is especially true if the water is static and stratifies in the bore hole. Am I missing something?
  • retiredguy
    retiredguy Member Posts: 1,037
    edited April 23
    Let me tell you my experience with a heat pump as primary heat and an oil furnace as back-up. In 1978 we built a 2 story 1800sf all exterior brick house about 30 miles north of Pittsburgh, Pa. The walls were R-24, the ceiling R-36+, Aluminum thermopane windows + outside storm windows. The heat pump was a Bryant rated at 34,000 btu cooling. I tested the heat pump over several winters and found that it could heat the house alone with no back-up down to zero degrees F. I was able to calculate that my break even point for heating costs heat pump vs oil was at about 20 degrees outside temps, so I set the outside temp cutout at that temp. The unit ran great for at least 20 years at which time we sold the house.
    ethicalpaulPC7060Kaos
  • TAG
    TAG Member Posts: 792
    The hype is always — electric heat is 100 percent efficient without the understanding of cost. What is the cost of that 100%. Heat pumps are then discussed as being 300% efficient vs straight electric resistance without the discussion of cost.
    I try to explain this to people all the time. NJ where we have homes is a perfect example. The state programs all require heat pumps to get the max rebate .. some home owners replace a gas furnace/ straight AC with a heat pump only and think they are going to be ahead of the game. The winter electric bills come in high and they get confused because they don't understand that the cost of a heat pump BTU with .20KWH electric is more than one with natural gas.
    hot_rod Member Posts: 25,170
    edited May 19
    SUNY Morrisville have been installing and monitoring HP performance around NY.
    I think NYSERDA has some calculators at their site also.
    John Siegenthaler had some systems running up above Utica, and one in the Albany area maybe. So he has some actual hands on data.
    His air- water and GEO heat pumps are in this issue.
    https://www.caleffi.com/sites/default/files/media/external-file/Idronics_27_NA_Air-to-water%20heat%20pump%20systems.pdf
  • leonz
    edited May 18
    My statement was poorly written and I ment to say-as the hotter discharged water drops back into the well at the static water level the heat dissipates as the cold water is pumped from the bottom of the well due to displacement.
    A semi open loop heat pump system acts just like a conveyor belt or a bucket elevator by lifting the cold water and letting the warm water drop back in the bore hole and this water eventually cools as it sinks to the bottom of the borehole and it becomes colder.
    There are at least three 1,550 foot deep drilled wells in Manhattan drilled into the bedrock that have semi open loop heat pump systems using ground water for heating and cooling.
  • winnie
    winnie Member Posts: 42
    I've posted this in other threads, so a summary:
    I live in Springfield, MA. I have oil fired steam heat and minisplit heat pumps. House built in 1935, insulated but in no way 'tight'.
    I've confirmed that the minisplit heat pumps will function (will produce hot air) at an outside temperature of -7; the units I own are rated to -5.
    I use the minisplits for heating when the outside temperature is above 32F, or if I only want to heat a single room above 20F.
    The minisplits are vastly more efficient than the oil/steam system for just adding a bit of heat to the house on a chill but not freezing day. This is a combination of the heat pumps having better COP when it is warmer out and the low effective efficiency of a boiler when 90% of the burn cycle is spent making steam in the first place and 10% is spent with steam in the radiators actually heating the rooms.
    As the outdoor temperature drops the minisplit heat pump COP drops, and the effective efficiency of the steam system goes up. So I happily burn the oil on the sub freezing days.
    I think I used 1000 kWh of electricity to replace about 200 gallons of oil consumption. My estimate is that I'd need another 3000 kWh to replace the last 130 gallons of oil consumption. So using the minisplits for the 'easy' days was a big win money wise, but it would be quite expensive to replace all my oil consumption with electricity.
    The other relevant comment: the warmish air from the minisplit is a less comfortable heat than the heat from the steam radiators. They feel exactly the same when I am coming down the stairs (no direct radiation, no direct air flow), but sitting next to the heat source it is clear that they are different. The barely warm fan blowing on me on a cold day? Not ideal.
    Rolling it back to the OP: I would suggest that when it comes time to replace your existing heat pump (they all die sometime) you go with a more modern heat pump backed up by burning fuel, with the plan to cross over somewhere between 20 and 30 F. You will net less total operating cost. But don't try to go to a pure heat pump system
    ethicalpaul Member Posts: 7,691
    …Unless that system is driven by ground water instead of air
    Great writeup, @winnie !
  • Kaos
    Kaos Member Posts: 654
    If your heat pump is blowing warm air, you have the wrong unit for the climate or it is down on refrigerant.
    In any place colder than zone 4 you want a vapor injection unit (ie Hyper Heat). These will easaly run down to -20F and supply hot air even on the coldest days. I run one at the cottage which is deep in zone 6 and it is nice and toasty even when it is -25C out.
    Older house with wall mount heat pump is hard to get right comfort wise as point source heat really doesn't work well. A better option is always a ducted unit with the registers under windows. Even in a old house, this works great for comfort.
    As for backup heat. In any place with expensive electricity, fuel burners will generally be cheaper to run. If you already have it, by all means switch over. If you look at the cost delta in most cases you are looking in the range of $100-200/year, so if the fuel burner gives up, there is no point in replacing it. Thus, if installing a heat pump, make sure to get the right unit and size it to handle your full load.
    PC7060
    Steamhead Member Posts: 17,833
    @Kaos said: "If you look at the cost delta in most cases you are looking in the range of $100-200/year"
    This would obviously change as electric rates go up. We've had some steep increases this past winter in Baltimore, and I doubt they will ever go down.
    Consulting
  • winnie
    By 'blowing warm air', I am comparing the normal operating output temperature of a minisplit heat pump to the quite hot output temperature of a fuel burner. I've previously lived in a house that had natural gas forced air, and I currently have steam radiators.
    I think that minisplits are often optimized for lower delta-T and higher efficiency. I'm pretty sure that the unit is operating correctly and normally, it heats my downstairs just fine, but when I'm right next to the unit the blowing warm air is not as comfortable as the heat radiated from the 100C steam radiator.
    Relevance to the OP is that heat pumps are often designed with a lower air output temperature then natural gas forced air furnaces.
    I currently pay $3/gallon for heating oil, and $0.30/kWh for electricity. With a COP of 3 I am just at about break-even.
    I agree, heat pumps are available to handle the full heating load even at very low ambient temperatures. But fuel burners are often oversized (because it is cheap to do) which means you have lots of excess capacity to take care of calculation errors or days colder than the 'design day'. (This comes at a real cost. The oversized system is less efficient and burns more fuel, but this don't get easily noticed.)
  • _doc_
    This is all great information…thank you all for sharing your thoughts and experiences.
    In the interim I have investigated further and discovered the supply and delivery charges for electricity for particular months in question do vary significantly, which would account for much of the difference I am seeing. But even in these early stages of comparing bills and usage month-to-month, it is becoming clear the gas furnace is the less expensive alternative
    So this is a work in progress. We'll continue to look at the data as it comes in each month, but I suspect the HP will "lose this battle" and be relegated to a very expensive air conditioner. We'll keep you updated as we move forward into the warmer weather.
    Many thanks for your input so far….
    edited May 31
    Why do you say the heat pump is a very expensive air conditioner? It shouldn't lose the battle except for very cold conditions.
    Have you asked your utility if there is a lower electricity rate for those who heat with electricity?
  • Kaos
    The BOM cost different between a cooling only fixed speed 3 ton AC only and a fully modulating cold climate heat pump air handler is about $2k. If I was comparing a modulating AC to the heat pump the cost delta would be a couple hundred.
    Definitely something, but compared to install costs, pretty much noise.
    A properly sized modulating heat pump will run much quieter and deliver more event comfortable heat than any fuel burner I've seen. The biggest complaint people have is they don't even notice it is running.
    @Kaos said: "A properly sized modulating heat pump will run much quieter and deliver more event comfortable heat than any fuel burner I've seen."
    That might be true when compared to a forced-air furnasty, but it will never be more comfortable than a well-operating steam or hot-water system.
    Consulting
  • Kaos
    @Steamhead
    Rads (water or steam) are comfortable because they deliver even heat and those dead old guys knew what they were doing and placed them where the highest heat loss was (usually under windows).
    A right sized ducted modulating heat pump with supply vents under windows, delivers even heat all the time right where you need it.
    pecmsg Member Posts: 6,170
    @Kaos
    As you said earlier
    When properly installed.
    add to that the complexity of the electronics and reliability can not be guaranteed 24/7.
  • Kaos
    "add to that the complexity of the electronics and reliability can not be guaranteed 24/7"
    In residential heating and cooling, very little nowdays gets fixed, almost always swapped out if there are issues. Sad state, but it is what it is. In that case it doesn't really matter what is inside the box or how complex it is since it will just get swapped out.
    I do find that modulating units are much easier on equipment as there is no inrush or startup loads. About the dozen or so minisplits, only issue I've had with one was at the cottage where power quality is questionable and a control board fried.
    and what happens in the dead of winter?
  • Kaos
    The exact same thing that happens when your boiler or furnace goes down.
    If you have backup heat, you turn it on. If not, go to the box store and get a handful of space heaters till the unit is either fixed or replaced.
    Consulting
  • winnie
    I know that I'd really like to try out some sort of minisplit radiator :)
    Much better chance of the boiler tech being able to get it running!
