Where to place Bleeding Valve on Baseboard radiator?
Ramesh_G
Member Posts: 1
All my Bleeding valve are placed at the return end, not feed side, of my baseboard.
Now the plumber placed a new tankless water system boiler and changed the direction opposite. The feed side is now return and that MAY BE created leak in my piping system due to pressure built in pipe. He says it doesn't matter which way they circulate. May be without bleeder Valves it may not matter but my all baseboard radiator has bleeding valves on return side where the water flows down (exist from baseboard). Can anyone tell me whether having direction change could affect my heating system.
I hope you mean a wall hung boiler, and not a tankless water heater. If he sold you a tankless water heater to power your heating system, he's incompetent. Wrong appliance for the job -- but he may be a good salesman.
Now. That said. Reversing the flow direction in a hot water heating system may or may not be a problem. In some systems, it isn't. In Monoflo systems, it's catastrophic. In series systems it will upset the balance between rooms; if it was satisfactory before, it won't be now. Do you have any idea how your system is setup?Br. Jamie, osb
Baseboards are usually in series, the hottest water is sometimes intended to go to the high load room firstBob "hot rod" Rohr
Living the hydronic dream0
