Questions Help installing new Oil water heater
Shuga
Member Posts: 25
Hello, I've run into some problems as I am trying to install my new Hot water heater. I bought a John Wood f307 to replace my 30 year old John wood F307. So I've run into two issues. 1 How do I hook up the oil to the motor? I can't see to find the connection. I am assuming I undo one of the brass lines and connect it to the oil filter instead?
Second, my old heater had a line labeled "Circulation line" Going to it, I'm not sure if it's a real circulation line but this new heater doesn't have a spot for it? Can I just leave it off if I close the line? Or is there some kind of adapter I can get?
Please help guys I've Been without hot water for days
Last pic is the old set up where the circulation line went, and the one above is where I think it should go0
The reason to call on a tech. is that he or she will have the necessary instruments to adjust the burner to burn properly. Oil burners are NOT plug and play; each one -- even apparently identical units -- has to be adjusted for best combustion individually, and that is not something that can be done by eye.Br. Jamie, osb
Id replace that with "Should" have the necessary equipment!Jamie Hall said:The reason to call on a tech. is that he or she
willhave the necessary instruments to adjust the burner to burn properly. Oil burners are NOT plug and play; each one -- even apparently identical units -- has to be adjusted for best combustion individually, and that is not something that can be done by eye.
Inform the contractor that you installed the water heater and need the gun set up properly!0 -
This is not a diy job0
Telling you it's not a DIY job is help. Its help in the way of precious advice. Whether or not you heed that help is up to you, and maybe your insurance company.Shuga said:Well it is already, so maybe some help would be better then "It's not a DIY job" I see that it's not, but I'm to invested haha0 -
You don't know my experience though, so I'm not really sure how you can make that conclusionHVACNUT said:Shuga said:Well it is already, so maybe some help would be better then "It's not a DIY job" I see that it's not, but I'm to invested haha
Telling you it's not a DIY job is help. Its help in the way of precious advice. Whether or not you heed that help is up to you, and maybe your insurance company.1 -
If you have the instruments to check the oil pressure, check the O2and CO2 and smoke in the stack gas, and check the draught, and know how to use them, fine. If you don't know how to use them, but have the instruments, please find someone to give you training on how to use them. If you don't have the instruments, don't try to do it yourself. Are you even sure you have the correct nozzle for that burner and boiler combination?Shuga said:Well it is already, so maybe some help would be better then "It's not a DIY job" I see that it's not, but I'm to invested haha
We are not being difficult. We are just trying to protect you, your family, and hour house.Br. Jamie, osb
I knew of your experience in your first post. I think it's safe to say that if you don't know how to connect the oil line to the fuel pump, then you sure don't have a combustion analyzer. Or smoke tester. Or draft gauge.Shuga said:You don't know my experience though, so I'm not really sure how you can make that conclusion
I appreciate your ambition, but there's a lot more to it than making connections, throwing the switch and walking away.
A lot of people can do a lot of things. Not a lot of people can do them right, and safe. Heck, there's tons of so called techs who I wouldn't let in my house. So the moral of the story is SAFETY. It would be a shame if you woke up dead and somebody here helped you do it.
Stay well.
2 -
I'm a DIY'er and I agree with what the pros are saying. If you can't find or read a manual for the pump that clearly shows where the oil line inlets are you shouldn't be going any further.0
- 123 Chimneys & Flues
