BTU
joera
Member Posts: 1
in Oil Heating
Need the BTU capacity for a Crane Sunday 15 boiler. Thank you.
This must be an old one. Maybe it's a Crane "Sunnyday"? If it doesn't have a nameplate with the Btu rating - then the only thing I can suggest is to keep Googling. Photos might help us.
Any clue as to what the fuel input is?Br. Jamie, osb
Posting some pictures will probably trigger someone's memory.joera said:Need the BTU capacity for a Crane Sunday 15 boiler. Thank you.
You could clock the meter and estimate the efficiency."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Good point. Do not just match the rating of the old one in place. The old one may be oversized and the building envelope may have been approved.Hot_water_fan said:Why do you need the capacity rating?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 120 Geothermal
