BTU
joera
joera Member Posts: 1
Need the BTU capacity for a Crane Sunday 15 boiler. Thank you.
  • Gilmorrie
    Gilmorrie Member Posts: 196
    This must be an old one. Maybe it's a Crane "Sunnyday"? If it doesn't have a nameplate with the Btu rating - then the only thing I can suggest is to keep Googling. Photos might help us.
    Any clue as to what the fuel input is?
  • Zman
    Zman Member Posts: 7,614
    Posting some pictures will probably trigger someone's memory.
    You could clock the meter and estimate the efficiency.
    Albert Einstein
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,243
    Why do you need the capacity rating?
    STEVEusaPAZman
  • Zman
    Good point. Do not just match the rating of the old one in place. The old one may be oversized and the building envelope may have been approved.
    Albert Einstein
