Hid my meter
i believe the utility has some rules about this0
I used to hate when people "hid" telephone splice boxes in such a way to make it difficult/impossible to work at them. And shrubs. But if you can do it while still allowing access, then thats cool.
You did say "portable", so that would work fine (well, maybe not up here .. it would be frozen stuck to the ground in winter !)
It definitely does look better with the lattice.
Currently in building maintenance.1 -
I like the concept but why so big? Seems like 3” wide would be plenty.0
Yeah but the photos are out of whack (to me) The tree on the left is missing , The weather vane in the yard is moved from near the meter and missing tree towards the front of the chimney and probably more if I look..... How long apart were the photos taken ?One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
The downspout by the door shows the angle change between the two pics.reggi said:Yeah but the photos are out of whack (to me)
The tree on the left would still be there, just out of the pic.
Currently in building maintenance.0 -
since you've asked, i think it looks much better without the lattice screen. perhaps, instead, you could plant some bushes in front of the meter, or paint the meter to blend in better.0
Agreed.
Better without it.
LOL, then you would hate me. I was in the alarm business, and what I did was remove the phone wire from the splice box and locate it through my foundation about a foot under ground (all utilities under ground). I then replaced the original phone wire with a fake that connected to my alarm system.Dave Carpentier said:I used to hate when people "hid" telephone splice boxes in such a way to make it difficult/impossible to work at them. And shrubs. But if you can do it while still allowing access, then thats cool.
Back in 1993 when I built my home, there was no cell service for alarm panels, just radio which was expensive and unreliable, and cutting the phone line was a common way to defeat central station notification. Sure, the local siren went off if the phone wire was cut but my nearest neighbor probably wouldn't hear my siren, particularly in winter.
So if someone cut my "phone" wire, central station would be notified through the buried hidden wire.
,0 -
The lattice draws your eye to it. It looks out of place. The meter blends better.0
The picture with the lattice is more straight on, without I was more to the right. It really does make it look like the trees and things moved. I prefer the lattice, but it is interesting hearing what others prefer. I got one gas bill thus far but no gas reader came over. I assume they don't come out in person to read the meter. Up close the meter is easily readable through the holes. I used the full 8' so it is offset. The large meter right in the middle to me is an eye sore.I'm not a plumber or hvac man and my thoughts in comments are purely for conversation.0
It is easy to move, a block leaning no each upward angled board on the bottom holds it, and the boards on the top keeps the space. It leans towards the house which the picture doesn't really show. So just gravity holds it. If the gas company says it isn't allowed I can carry it off in 10 seconds.
I'm not a plumber or hvac man and my thoughts in comments are purely for conversation.0 -
I think it would look better if he printed out a brick wall with a gas meter in front of it and glued it to the lattice.MaxMercy said:Maybe if the lattice was more of a brick color?
4 -
Gas meter from the last 15-20 year are wirelessly read from a moving vehicleJersey2 said:The picture with the lattice is more straight on, without I was more to the right. It really does make it look like the trees and things moved. I prefer the lattice, but it is interesting hearing what others prefer. I got one gas bill thus far but no gas reader came over. I assume they don't come out in person to read the meter. Up close the meter is easily readable through the holes. I used the full 8' so it is offset. The large meter right in the middle to me is an eye sore.
STEVEusaPA said:
Looks like a meter highlighter. Looks worse.
ChrisJ said:Agreed.
Better without it.
Another example of If you don't follow the way I think it should be, then you are wrong and should be admonished or censored. but that is the way of the woke generation this country is leaning towards.HVACNUT said:The lattice draws your eye to it. It looks out of place. The meter blends better.
Not really.EdTheHeaterMan said:Looks like a meter highlighter. Looks worse.
Agreed. Better without it.
It's an example of our opinions are different.
I would like to think that's allowed.
At least you thought my joke was funny.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
I have seen many meters painted the color of the house. I never heard of a fine or charge or penalty for making your meter brown or blue or even pink. Just don't paint over the little plastic window.MaxMercy said:Would the gas company allow painting the meter to match the house I wonder?
It's pretty cool that it transmits and doesn't need to be directly read. And with the meter hidden or not hidden, nobody even looks or thinks about it to be honest except the home owner. How many houses have garbage and recycle bins in their front yard that we even notice. A new idea, I can put my recycle bins in front of it heheI'm not a plumber or hvac man and my thoughts in comments are purely for conversation.0
Or thisBob "hot rod" Rohr
Living the hydronic dream3 -
@hot_rod that is one of those new super efficient brick split systems. Made so well they covered it with brick! Would stick out in front of clapboard though.....Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
I can't tell if you're trying to be funny or not. If you were going for a laugh, I don't get it. If you're serious, it doesn't make sense. I see no admonishment or desire to censor the OP in any of the 3 quotes you posted. While some might be woke, others need to get their rest. Its almost like you just finished ranting on some political forum, then came here while you were still jacked up.EdTheHeaterMan said:Looks like a meter highlighter. Looks worse.
Another example of If you don't follow the way I think it should be, then you are wrong and should be admonished or censored. but that is the way of the woke generation this country is leaning towards.0
