hang on to R22 equipment
So maybe replacing R22 with propane will be allowed?
Next question is can we make our own propane refrigerant from fuel propane?
Is propane the right hydrocarbon or should it be something heavier?
There is always the option to just build a system that doesn't leak...0 -
BBQ Propane etc is typically considered dirty and is often different blends so it's inconsistent.jumper said:New standards allow new large HC refrigerant equipment.
I highly doubt it would ever be allowed on a professional level no matter how much you try and filter it.
That being said, I know of someone that has used unfiltered BBQ fuel many times as refrigerant with success at least in the short term, but not on a professional level.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Regular BBQ Propane is explicitly banned from use as a refrigerant by the EPA. I can't site the exact rule but I remember that on my EPA 608 test.
Perhaps it is banned because of the whole explosion thing, not so much because it is BBQ grade?0
Please read my post above.mattmia2 said:Perhaps it is banned because of the whole explosion thing, not so much because it is BBQ grade?
Why do you feel LPG in an air conditioner is more dangerous than it is on anything else we use?
Stove with burners you control manually, clothes dryer etc, all connected with either piping with threaded joints or tubing with flare connections often connected to a 500 gallon tank.
But an air conditioner with all brazed connections, no valves that can be opened by a user in a system that holds a few pounds is dangerous?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
That really wasn't the question. The question was about the EPA exam question. The EPA rules explicitly ban flammable refrigerants. That is most likely what the exam question is getting at.0
LP AKA R-290 is allowed but in very small quantities, 6 or 8 oz total charge for small refrigeration systems. 1/4-HP or less.
Doubtful you'll ever see it in A/C equipment.0 -
I also. Especially when one cannot repair leak like sometimes for car a/c. I heard that somebody was jailed for "fixing" car a/c s that way.ChrisJ said:
That being said, I know of someone that has used unfiltered BBQ fuel many times as refrigerant with success at least in the short term, but not on a professional level.0 -
But an air conditioner with all brazed connections, no valves that can be opened by a user in a system that holds a few pounds is dangerous?0 -
I think I need to freshen up because it looks like a lot has changed since I did my 608 and 609. 609 especially, since that's been over 1.... 18 years holy crap 18........ years.
Where did time go?
That is about when I contacted a few of the places listed by the epa as giving the exam and of the few that even responded none were actually giving the exam so I found someone selling r22 that wasn't asking many questions.ChrisJ said:I think I need to freshen up because it looks like a lot has changed since I did my 608 and 609. 609 especially, since that's been over 1.... 18 years holy crap 18........ years.
Where did time go?
The Viessmann A2WHPs are r290, LPBob "hot rod" Rohr
Living the hydronic dream1 -
They're using R-290 on refrigeration in the USA. But only in units with a very small charge.
R-32 is being used in Japan & Australia0
