trying to learn from a mistake
hey guys, I've been reading the board and learning how to install hvac stuff for a few months on a derelict farm I bought. Getting better but I made a lot of mistakes in the beginning and didn't have proper equipment, etc. Early on I installed a single 18K Senville mini split from amazon and a few weeks later it stopped working. Didn't diagnose or fix it until a few days ago--the pcb board in the outdoor compressor failed, I swapped it, everything works now. As I was pumping the refrigerant down into the compressor to move that unit somewhere else I noticed I had barely opened the valves to let the refrigerant into the system after the initial vacuum. Obviously that's dumb and that must it created a restriction that made the unit fail, but the compressor is fine, it's just the pcb. There's nothing visible on the board. Any idea what could have caused it to fail in that case aside from my stupidity?
  • Ironman
    Ironman Member Posts: 7,887
    Maybe a power surge? Did you put a surge protector on it?
    Bob Boan
    mthmlf84
    EBEBRATT-Ed Member Posts: 19,891
    probably short cycling from starting and stopping without the proper refrigerant flow
    mthmlf84
  • mthmlf84
    mthmlf84 Member Posts: 27
    interesting, no surge protector no, I have one on all the other compressors I installed (that are running great and didn't fail).
    pecmsg Member Posts: 6,894
    edited April 2022
    C heap
    C hinese
    C rap
    MaxMercy
  • ChrisJ
    ChrisJ Member Posts: 17,158
    pecmsg said:
    C heap
    C inese
    C rap
    What is Cinese?
    ChrisJ said:
    pecmsg said:
    C heap
    C inese
    C rap
    What is Cinese?
    They can't even translate correctly!
    MaxMercyAlan (California Radiant) Forbesmthmlf84
