forced hot water boiler town increased water pressure
gage123
Member Posts: 3
the town increased my water pressure now my shower hot water only lasts for a minute and then gets colder. what do i adjust?
How is your hot water made and stored? Indirect? Stand alone? Tankless?Br. Jamie, osb
tankless , forced hot water. coil setup on the side. wel mclain0
I have a ball valve on the same line going in ,adjusting that will that do it or does it need the pressure reducer?0
You need the pressure reducer -- a ball valve isn't the same thing at all. Leave that wide open.Br. Jamie, osb
Probably a thermal expansion tank also, they may have added a backflow device.
Put a gauge on a hose bib to see what pressure they are sending you. 55- 60 psi is adequate. Code suggests 20 -80 psi max.
Above 80 psi you may have issues with faucets, toilet ballcocks, etc.Bob "hot rod" Rohr
- 50 Industry Classes
